Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
LCD TV screen goes blank with sound still on
My LCD TV screen goes blank with sound still on after the TV has been on awhile. If I press the on/off switch a few times the screen will reappear but then turn off again after awhile. My solution was to run an external fan onto the back/top of the TV and that seemed to do the trick (the back/top was hot). Now, with the summer heat, this does not always work so I want to really solve the problem.
  • 1 more comment
  • Causetocycle Nov 15, 2008
    after tv has been on for a while, I get a blank screen but still have voice. I have to turn the TV off for a while then turn it back on.
  • toolman44847 Dec 21, 2008
    i have the same problem but the fan trick didnt work???? checked all boards and question my mainboard...has a few things on it im scratching my head too i dont know..but everything else looks fine...im getting mad it at...anyone want a free tv u pay shipping lol
  • aap145 Jan 03, 2009
    I have the same problem but it is random. Some days it does not happen at all and other days it happens about every 2 minutes. It very frustrating!
    I do not think it is a fan issue b/c it happens when it is cold and hot...
    Any help is appreciated!
    Genius:
  • 1,112 Answers
Have the inverter board checked for cold solder joints, this television is notorious for bad connections on the small transformers on the inverter, buy the way the inverter is the board that lights the lamps.
Thanks please leave comment
Posted on Oct 08, 2009
    Scholar:
  • 21 Answers
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
My solution so far has to been to run a fan onto the back of the TV screen near the top. This has kept the screen lit once it has been turned back on again. A more permanent solution based on my research appears to be replacing some electronic part, maybe the LCD Inverter. I have so far elected not to go that route.
Posted on Nov 16, 2008
The TV screen goes blank and there is no sound...if we wait for awhile...the picture reappears.
you should bring your unit to a qualified service pesonnel, problem like this is not a DIY act unless your a professional serviceman.
here are the check points
power supply,
X or Y sustain board,
bad screen (PDP panel),
logic board,
buffer boards
these sections of your TV are replaceable board.
the least you can do is just replace first the bulging/deformed capacitors.
begin with the power supply section..
after replacing try to pwer on again
good luck!
Feb 08, 2011 | Sony KDF-E55A20 55 in. LCD Television
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Hitachi 65F710 tv goes blank for a second...
sounds like a possible flex module problem. repair is usually abut $500- $600.
Apr 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Screen goes blank, sound still on
even though lamp came back on and worked for awhile, it was a bad lamp. replaced lamp and set works
Mar 23, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Guide plus
can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Jan 10, 2008 | RCA F32649 32" TV
Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Dec 02, 2007 | Thomson LCDB 03B 27 in. Television
Pop up box appears periodically
try bringing up the menu, and see if there's an option "factory default", and try that. you didn't mention what button on the remote you press to get rid of the popup, or what feature you are turning off to get rid of the popup,
Jun 28, 2006 | Samsung LTM1575W 15 in. LCD Television
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
561 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
