Question about Epson Stylus CX3200 All-In-One InkJet Printer
Red ink not coming through
Computer says we have equal amounts of coloured ink (about 50% left), but none of the red pigment is coming through.
Any suggestions on how we can fix this problem much appreciated.
(We have recently replaced the black cartridge, which took several attempts and a few days before it would print clearly).
Has anyone used the product "Magic Bullett" to clear blockages - does it work?
    Problem Solver:
  • 5 Answers
Hi, Epson usually recommend at least 6 cleans of the print head to clear any blockages. However, be warned this can use up a lot of the remaining ink, and may not resolve your issue. You may have dried ink in the magenta tank, and I would suggest replacing the ink if the first solution does not work
Posted on Aug 30, 2008
Ink cartridge colour not detected how to repair this problem
If these are BCI3 BLK cartridgesicon1.png they may be old or the pigment has separated.
Shake the cartridge and hit it lightly on a towel to see if inkicon1.png comes out. If it does (I mean an amount close to the hole size) try a nozzle test.
If that does not work you may have to deep clean the head.
You may also look on the left side of the printer after opening the tray door and look for a 3 inch x 1/14 inch silver plate with two red dots on it.
take a q-tip and soak it in isopropryl alcohol and clean the dots.
These are what the printer uses to align the pages and show ink volume and identify cartridges.
thank you for using Fix-Ya
Apr 23, 2014 | Canon PIXMA MP780 All-In-One InkJet...
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
Desoite changing all the cartridges and running print head cleans - the colours are not coming out correctly - the reds seem to come out much darker (almost pur magenta and the brown /yellow mixes also...
Few things to consider:
Are the new cartridges the same as the ones you took out (same make, same type)? If not this is the likely cause.
I am not to much in to Canon printers but probably like Epson they will have different types of genuine ink, you know longer lasting, brighter etc depending on how much you want to pay. Also you may have had Pigment Ink in before and now have dye inks or vise versa
Are your print setting the same (printers can be adjusted to print draft, text, or photo)
Are you using the same paper? Non-photo paper will significantly dull the colours.
Hope this finds you the reason. Best of luck.
May 04, 2011 | Canon Office Equipment & Supplies
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Jan 24, 2010 | HP DeskJet 990cxi InkJet Printer
Prints in blue and green ; all ink cartridges are
Dear Dahcota; If it has a single color cartridge, there are three components inside the cartridge-red, green, blue, and all colors are a superimposition of these 3 basic colours RGB in different proportions. It looks like the red component has run dry. So, what you get is the color without the red component. If its showing all cartridges as being full, sometimes these levels shown are inaccurate. Try changing the entire color cartrigde or red component, then see if you still have the same problem. What I am not sure is if the red cartridge is a separate entity . If the red is separate, and changing it does not improve things, the connection in the printer might be faulty. Go to www.hp.com and browse for the correct make ask them online there, It should really be okay, once you have replaced the red or entire color cartridge is it is a single unit with all 3 colours
Oct 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
No black ink printing all other colours okay
This is getting to be a very common problem that I've found almost constantly with the HP88 K/Y (Black/Yellow) printhead. The problem is that the Black ink is pigment ink and in certain environments this just clogs to the point that no amount of cleaning will actually resolve the clog and you have to replace the printhead. The only long term solution I've been able to find is to replace the black cartridge with a 3rd party dyebase ink cartridge and run this through a NEW printhead to replace the pigment ink in that. Dyebase ink does not have any of the same problems and will work perfectly. The only trade off is of course that you lose your warranty and there is a certain amount of ink "bleed" where the edges of black are more fuzzy from ink mixing while it's wet but this is fairly minimal and as the L7580 is only really a document printer (rather than a photo one) it shouldn't make a huge difference. I've used this approach to great effect both at home on an L7680, K5400 and K8600 plus on the same models in 3 different schools where this clogging issue occurred so it's tried and tested. Hope it helps.
Jun 10, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
No red colour in my lg lcd monitor ..red colour setting doesnt bring any change i screeen..pls suggest some solution
it is very simple, by default in monitor circuit RGB (Red, Green, Blue) tube is installed. and in combination of both of three colors we are able to view colorful image. due to non functionalty of Red color u r not able to view red color in screen, either you replace picture tube or purchase new monitor. coz cost of this tube is equal to monitor.
Jun 05, 2009 | LG Flatron F700P 17" CRT Monitor
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Ink or printers problem
Most likely the ink cartridges for this printer have a chip on them. This chip tells the printer how much ink is left and when it is low or out, you must replace the whole cartridge otherwise if you just refill it, the chip will still report the same amount of ink as it doesn't go by the actual ink level inside the cartridge, it determines the ink level by calculating approximately how much ink has been used while it was printing. So it doesn't matter how full the cartridge is, unless you replace the cartridge or reset the counter on the chip somehow, it will still display the calculated amount not the actual amount.
Jun 10, 2007 | Compaq Armada M700 Notebook
Epson Stylus CX3200 All-In-One InkJet Printer Logo
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
