please check if you can remove and reinsert the hard drive from its's location. usually you would have to remove 3 or 4 screws on the bottom part of the laptop and slide the hard drive out. once it's out put it back in and make sure that it's tightly on its place.
If this does not work you may have to replace the hard drive because the message means that it cannot detect the hard drive and it might just have to be replaced.
Possibilities:
#1: the "data" cable to the disk-drive has come loose -- no "data" can be read from the disk-drive
#2: the "power" cable to the disk-drive has come loose -- the disk-drive cannot spin
#3: the disk-drive has "died" -- either its electronics have failed, or the motor that spins the disk-drive has failed.
No disk-drive means that you cannot install Windows.
Buy a new disk-drive, and install it. Re-install Windows.
Buy an external disk-drive, and use it to keep weekly/monthly "backup" COPIES of your important files. Do *NOT* copy files to the external disk-drive *AND* delete them from the 'C:' drive.
