FixYa.com
Tags:
D-Link DSB R100  Radio Input
D-link USB Radio (by 2 users)
By Hart - usenet poster
I have a D-link DSB-R100 USB Radio.  I am having a problem with the
radio playing sound through my speakers at Windows start-up.  It seems
like the radio is broadcasting radio station 87.00MHz, which is just
static.  The only way to make it stop is by opening the D-link USB
Radio software and then closing it.  I've tried downloading the latest
software and drivers from D-link's website, but that did not help.  I
sent a message to D-link's tech support a week ago, but they have not
replied.  This is annoying the hell out of me and I am desperate to
find a solution.  Does anyone who has this radio know the fix?  Thank
you.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 07, 2008
yes can not get radio
Best Solution
posted on Aug 11, 2005
FixYa! (100)
lawyer
lawyer - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In article <MPG.159501a9f195e838989 @news.easynews.com>, viking says...
I bought this device from CircuitCity in a free-after-rebate offer last weekend
and I am trying to get it working on a windows 2000 machine. For some reason
though the device manager shows this device and says it is working properly,
starting the radio program gives an error saying "Cannot find the FM Radio" and
suggests me to unplug and replug. I tried it for no avail. The program starts
after that but disables all the controls. Any clues on what might be wrong ? Any
suggestions ?
Thank you,
Hari
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
In article <tj51spsctcc @corp.supernews.com>, M. Smith says...
I don't have any replicator or hub on my machine. But I do have two ports at the
back and two at the front and all the four are supposedly directly connected to
the motherboard. But I though I should try connecting to the back anyway, and
guess what, it worked, but I don't think d-link recommended the same for this
device. It is a pain reaching the back of the pc. I already have 2 usb devices
connected at the back that I use regularly and I use the front two to hot swap
devices. In this case it is not going to work out this way.
But wait a min.... I just moved it onto the front USB port and it still works
(now the audio wire doesn't reach the sound card though). Don't know what is
going on though. Let me see tomorrow after rebooting if this still holds.
Thanks for your suggestion.
Hari
Solution #3
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
In article <tilrmvgs3kt @corp.supernews.com>, fierobi @hotmail.com
says...
ftp://ftp.dlink.com/usb/dsbr10 0/Driver/
the radio app doesn't crash as much with the 600b;
just delete or move it out of start menu/startup and you'll be fine
Solution #4
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
I had the same problem so I took it out of the start menu.
had to restart the program to shut the radio off.
what I came to this discussion was to ask if anyone knows
of a 3rd party radio program that will control this device?
I dislike the interface. You'd think that D-link would hop on
board the skinning bandwagon like realplayer and WMP did. how about a
winamp plugin? that would b nice! i was going to return it but
compusa has a horrible 15% restocking of opened boxes!! scum!
Anyone got any leads?
Thanks
Bill
Posted via CNET Help.com
http://www.help.com/
Solution #5
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
I had a horrid time getting my D-Link DSC-350 camera to work on my PC.
Turned out I was trying to use it through a USB port replicator.
My Dell had 2 USB ports on the rear but the computer is in a location where
it's a major pain to access the rear ports without shutting everything down
and moving the box. I had installed a 4-port USB replicator on the front
panel of the machine in a 3 1/2" slot and all other USB devices worked fine,
including my color scanner.
Finally, after a weekend of headaches, I stumbled across some fine print
that stated the camera needed a USB port wired directly to the motherboard.
Switched the one D-Link cable to the remaining rear port and the camera has
worked like a charm since.
Could this be the case with your D-Link device?
Solution #6
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
Well, in doing research on Google to find a resolution to my problem,
I found a review of the USB Radio on this website:
http://www.electic.com/Reviews /D-Link_USB_Radio/index2.shtml
Here's a quote taken directly from the review:
"...Finally the only way to turn off the radio from coming over the
speakers is to open the program - which is not running - and then
close it..."
This is exactly the same problem that I want to resolve.  What a piece
of crap this radio is!  Unfortunately, I'm passed the 30 day return
window, since that's how long it has taken me so far to try and
resolve this!  If anyone has any other suggestions, I'm open to them.
Thanks again.
On Fri, 18 May 2001 19:20:13 -0700, John <joh @altavista.net> wrote
"D-link USB Radio":
Solution #7
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
In article <9e92h6$p1 @slb1.atl.mindspring.net>, matty91
@mindspring.com says...
sounds like windows problem; do you have it plugged into USB as well?
check device manager, too; the radio drivers aren't as plu&play as
they should be; here's the url for the latest driver/app
Solution #8
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
Try going to the sound mixer (double-click the little speaker icon on the
task bar) and mute the sound from the line-in. Then reboot the computer
(important) to save these as the default mixer settings. I have a feeling
that the radio application will unmute the Line-in upon opening and then
mute it again when closing.
-Eric Gross
Solution #9
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
In article <9e76oj$is @slb0.atl.mindspring.net>, matty91
remove the radio from the 'startup menu'; plug it into the 'line in'
hole- second from the right
Solution #10
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
Eric, thank you for your suggestion.  I tried your suggestion and it
sort of works.  You were right, the radio program will uncheck the
mute in the volume control.  So I would have to recheck it each time
the radio program is closed.  The other problem is the USB radio
continues to turn on and sound static through the speakers during
boot-up, until the volume control is loaded in the tray bar.  By
having the mute checked in the line-in under the volume control, I'll
hear the static for about 5 seconds while the computer is booting, but
I'll have to make sure the mute is checked each and every time I close
the radio application.
I'm still looking for a way to make the USB radio not send sound to
the sound card at all.  I wish D-link would respond to my tech support
e-mail.
On Fri, 18 May 2001 22:45:10 -0400, "Eric Gross" <e @po.cwru.edu>
wrote "Re: D-link USB Radio":
Solution #11
Not Rated (0)
man1
Rating: 0%, 0 votes
That is where the card is currently plugged in. Each time I try
to open dlink radio it tells me "Cannot find Radio". I have
windows98 SP1 and the latest dlink from drivers. You didn't
plug the device into the sblive card did you?
Thanks for any info,
- Ryn
Solution #12
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
Any idea which port on a SBlive 5.1 platinum the "line in" cables goes to?
- Ryn
Can you Help with these Input Adapters problems?
Input Adapters
need to know where to
need to know where to hook... Answer This...
Input Adapters
drivers for toshiba dynabook...
my Japanese friend ask me to... Answer This...
Input Adapters
Using my new 256mb
I was trying to upload some... Answer This...
Input Adapters
fire wire
what does the port look like Answer This...
Input Adapters
Wireless connection
The connection works sometimes.... Answer This...
Repair Service
Find Input Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
