Question about Brother MFC3240 Multifunction InkJet Printer
My brother mfc 3240 won't print
The screen says "unable to change". i opened the cover looked for jams and turned the machine on and off and still says the same thing.
  • Anonymous Nov 13, 2008
    MY MACHINE WONT PRINT FAXES
    Scholar:
  • 152 Answers
What are you trying to do when you get that error message? Are you trying to change the cartridges or is this when you are trying to print?
Posted on Aug 23, 2008
PRINT UNABLE 70
You would need to remove jammed paper opening back cover.
Nov 18, 2013 | Brother Mfc 250c Clr Inkjet P S C F Usb...
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
Printer has unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
Then with the power on, pull the plug from the wall for several minutes. The plug it in and power the unit up.
Here is the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 18, 2008 | Brother MFC 420CN All-In-One InkJet...
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
Unable to initialize
If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine
To clear paper jams:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
You may have to copy and paste the link into your browser.
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Unable to print
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
  1. If the error continues to appear, the machine may have a mechanical problem.
See page 123 of the manual for more. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Sep 02, 2008 | Brother MFC 210C All-In-One InkJet Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-440CN printing error
I encountered the same problem. I just took all what's left of the paper from inside of the machine and than took off this plastic cover from the back of the machine. Than "unable to print 34" message disappeared, and "receiving data" message appeared on the lcd. Without the plastic cover machine released 3 pages and showed this message about paper fed. Than I put the cover back on it's place and pushed the green button (colour). Than again "receiving data" and mfc 440cn just printed requested documents. I have no idea why it was so simple, maybe i was lucky, no harm in trying after all, good luck!
Oct 30, 2007 | Brother MFC 420CN All-In-One InkJet...
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
