Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
My son's 4 wheeler stopped working so i just bought a replacement battery for it. it seems to drive just really slow. i charged battery for 18 hrs. and still doing the same thing. it runs slow then catches speed then slow again. never really runs fast like it did to begain with
    Genius:
  • Fisher Price Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter
Posted on Jun 19, 2012
SOURCE:
  • 3 Answers
SOURCE: It just won't start
If you battery is old, has continually gone a month or more without being charged, or has been left charging for extended periods of time it could be the battery. But it could also be one of the switches getting dirty. I would suggest going to www.modifiedpowerwheels.com They have all the info you could every want on how to troubleshoot and fix these.
Posted on Dec 18, 2008
  • 156 Answers
SOURCE: how to operate a used power wheels ninja?
It sounds like your power wheels battery is low. Have you charged it up for more than 18 hours.
I seems like power is getting to the back of the toy, so I think it might be the battery.
I would also ask the people at this website http://www.shopjandl.com/kids---baby-ride-on-toys-power-wheels.html
Posted on Apr 23, 2009
  • 156 Answers
SOURCE: I just acquired a used Kawasaki Ninja Power Wheels
Usually the clicking noise is caused by a crossed wire in the foot pedal.
I would contact the guys at this website http://www.shopjandl.com/kids---baby-ride-on-toys-power-wheels.html
They seem to know how to figure these toys out.
Hope this helps
Posted on May 13, 2009
  • 3 Answers
SOURCE: bought new battery for power wheels-charged it for 18 hours and t
It will most likely be the Failsafe foot pedal switch. You can pull that switch out and order a new one through online vendors such as Amazon.com or you can make the repair on the spot by purchasing a "sealed 60 amp starter button" from your local autozone and replacing this for the old one. You will have to make it fit in the old compartment, but that can easily be done with an oversized washer. If this toy truck has three wires going to the pedal switch and most likely it does, disregard the orange one and only connect the white ones and the red one. That fixed the problem on my little one's Fisher Price Power Wheels Escalade. You can also check if the battery is good and if the motors are working by simply connecting each motor to the battery with a pair of gator clips and some cables. <!-- from fixya rte -->
Posted on Aug 10, 2010
SOURCE: High Speed on the Kawasaki KFX Ninja four wheeler
Does anyone know the answer to this?
Posted on Dec 25, 2010
What's wrong: Thomas ride on music is working moves a bit then stops
Hi, Batteries tend to fail on charging if not used for a while- try a really long charge and see - if it still fails to hold a charge - the re-chargable battery will need replacing.
Dec 07, 2017 | Peg Perego IGED1084 Santa Fe Train
Peg perego 4 wheeler
is it a 12v or 6v four wheeler?
Jun 27, 2013 | Toys
Just bought one of these and it seems like it doesn't hold a charge it goes pretty good and thanafter 15 mins so slow??
Battery powered vehicles like scooters and golf carts have trouble going up hill because smaller electric engines aren't powerful enough or made for nothing more than flat land. You could have a bad battery or the battery isn't being charged enough. I know someone that has a golfcart and it takes approximately 48 hours to charge full. You may want to check the manual about charging times.
Sep 16, 2012 | Razor E200/300 Electric Scooter Battery
Regarding back up of battery
LOL, Nope, there is no problem with the battery. That's the way it's supposed to work.
When you run on the battery the laptop reduces or stops certain things to conserve battery power. Haven't you ever noticed that once you remove the power cord the screen goes dimmer. The laptop is conserving energy and that will cause it to perform at a slower pace or speed.
Unplugged laptops generally go into power saving mode. They will slow the CPU speed, stop the hard drive more often and lower the brightness of the screen (big power savings) all that good effort is lost when you remember that the power supply you use to charge the battery is making more heat . When you reattach it to the power adapter it goes back to Full Power Mode, and recharges the battery as well.
Here's a rule of thumb that I always follow. If i'm near an electrical outlet, I use the power cord. I never use my battery unless there is no electrical outlet near by. This way my battery is always charged for times that I really need to use it.
May 18, 2012 | Compaq Computers & Internet
What's wrong with a infinity i30 when it has a
2 possible solutions. 1 or more serpanteen belts are not engaging ( slipping will smoke like he'll! I burnt all 3 when I started my j30 '96 after almost 2 years! Had to charge the battery overnight..everyone really should have one! Times like that you are gladjya did! And my battery was replaced the day I stopped driving it!). Either that...clogged fuel filter. Seriously, it happened in all three j30's I have owned, and one Jaguar XJ6 with saddle back gas tanks. $55 usually to change...maybe a lil' more depending the garage hrly rates.
Mar 29, 2012 | 1997 Infiniti.5 J30
I used my Worx trimmer successfully last season. This spring when I went to use it, it would not hold a charge. The light shows green on the charger but the trimmer only works for about a minute before...
Your battery is shot. I had one of these, the batteries are really cheap and don't last long. If you can afford it, ditch the Worx and buy a quality trimmer at your local hardware store. If you are short on cash you can buy new batteries online.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
My son has a 700 twin sportsman peg-perego four wheeler. Weve charged thae battery . But when we hook it up the four wheeler will only go really slow as if the battery is dying or dead. Does it need a new...
check the battery with a multimeter and see if its showing 12 volts or more, if it is showing volts but not 12 or more then put it on the charger for about 8 hours, then check the battery again if it still hasn't went up check the voltage of the charger with the multimeter and make sure that the charger is putting out 13.8 volts or more, iif it isn't then you need a new charger, if it is then you need a new battery
Nov 30, 2010 | Peg Perego 12v Battery
My son had peg perego 4 wheeler electric and I had extra battery He only 1 cricle around the house and it stop even battery been charge please help
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Aug 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
434 people viewed this question
Top Fisher Price Toys Experts
Marvin
Marvin
NOEL
NOEL
yobo007
yobo007
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
