Follow these steps to remove / disable the BIOS (CMOS) Password on the
Satellite A210 /
A215 (
PSAFGx ) models:
1. Turn the computer OFF, if it's on.
2. Remove the memory module cover, on the bottom of the computer.
3. Check the configuration of memory modules in the two sockets. It's necessary to have a memory module present in the outermost socket only.
If there is a memory module in only the outermost socket (the one farthest from the system board), then continue to step 4.
If there is a memory module in only the innermost socket, move it to the outermost socket.
If there are memory modules in both sockets, remove them both, then re-insert one of them into the outermost socket.
4. With the computer oriented as in the photo above, carefully peel back the black Mylar film. Pull this film to the side enough to expose the
B500 solder pads (see photo below). Tape the film to the computer's case, as shown. Do not remove the film completely, because it may be difficult to re-attach it correctly.
5. Short the
B500 solder pads on the system board. Needle-nose pliers or a flat-blade screwdriver works well to short them.
6. While continuing to short-circuit the solder pads, turn the computer on, and continue shorting the pads until the Toshiba Logo Screen disappears.
7. Re-position the Mylar film over the system board.
8. If you removed a memory module, turn the computer OFF, then re-insert it.
9. Re-attach the memory slot cover.
10. Restart the computer to verify that the password prompt no longer appears. If it does still appear, then repeat this procedure, starting with step 1.
