Soap tray does empty
The machine fills with water normally and revolves but the soap and rinse aid does not get washed out of the tray. Help!
  • Anonymous Mar 15, 2014
    Soap / conditioner tray filling up with water
  • 876 Answers
Try pouring some really hot water into the trays and running a quick wash.
Posted on Aug 18, 2008
At the end of cycle I find soap suds, a lot, in bottom of machine have tried cycling vegetable oil, still have some suds left
Run the machine empty with a bar of everyday soap (not sure what you have stateside but in the uk it would be something like LUX or SHIELD the solid block type). This should kill the suds already in the machine. If the d/w is creating a lot of suds, it could be because you soaked an item in regular hand wash liquid and didn't rinse it well enough before finishing it in the d/w or the rinse aid is set too high or not dosed correctly. If you had just filled the rinse aid then you may have just been a little heavy handed and allow excess into the machine. When you refill rinse aid and salt it is best to run the shortest wash to clear any residue spilled. Hope this helps
Apr 10, 2013 | Bosch Dishwashers
My new dishwasher leaves a white residue on my pots. pans and stainless flatware. I have not changed soap. Could the water not be hot enough?
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Sep 19, 2010 | Whirlpool Dishwashers
Machine wont empty properly pump seems to work. machine sounds like its operating normally bosch classixx dishwasher
dont use soap with jet dry or rinse aid in it. use regular cascade soap and fill completely with jet dry rinse agent. your unit is over sudzing .if this is helpfulto you send me a 4thumbs up post
Feb 16, 2010 | Bosch 24 in. SGS43C12 Classixx...
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
Epic Z - Water coming out the front soap tray
you can try pulling the soap tray out and clean all the old detergent and softener in there. they do clogged the outlet of water for the water to overflow.
check also where the soap box is inserted. it would also have lots of dirt.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Washing Machines
Soap dispenser not working
It sounds like the water valve has a clogged filter.  Shut the cold water to the washer off, disconnect the hose and remove the filter screen in the washer water valve.  Clean out the filter with toothbrush.  Reinstall and everything should be ok.
Feb 18, 2008 | LG WM-1485FHD Front Load Washer
After cycles complete, some soap still left in machine.
try wash it empty add no soap.. at the end of the wash cycle before it goes into spin open the lid and see if you have soap bubbles.. if you do have have a build up of soap and are using to much or the wrong soap for you area... let me know what you find out...
Aug 27, 2007 | Frigidaire GLWS1233A Top Load Washer
Water Leak
Raf, remove the soap dispensor and check to see if you have a bottle cap gasket blocking the fill port. Just use your finger and probe around where the port is. Catriver..post back.
Oct 16, 2006 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
