Question about GE WBVH6240F Front Load Washer
Washer is not tumbling after water fill.
We had a power failure and since then the washer is not tumbling during regular cycles. It does spin and do the left-right tumbling whenever I start a new program but after filling the water in it does not tumble. Lint filter is clean. Service test mode 10,11,14 will not run. pressure switch test runs OK. No error reported (E00).Seems like the inverter program corrupted. Do I need to replace it or there is a way to reset it?
  • 1 more comment
  • zllib Sep 04, 2008
    Our washer stopped tumbling and removing water from the load after power failure, also, this week.
  • mom2hannah Sep 21, 2008
    we had a power failure this week and the drum will rotate, drain water, etc... but it won't spin. it just hums during the spin cycle.
  • dori2zv Oct 06, 2008
    The inverter circuit on the GE front load machines have a surge protector inside. However this fails to do the the job. As a result, GE customers have to bare the cost of replacing the unit (~$200 + labor).
    The other thing is that the diagnostic tests fail to report on such a failure, which make you think that you should look somewhere else.
    Novelist:
    Champion:
  • 261 Answers
You may have a corrupted ccu or relay. Does the machine drain and is there an error code? It starts ok and then does not continue and the pressure switch is ok? You may want to remove the swith and lightly blow into it and check for continuity and then ohms. Any small measure and I would replace it. Also if the ccu says it is ok and it is not then I would question the ccus ability to function normally.
Posted on Sep 11, 2008
Suds display and F35 error message
The F-35 is associated with this little gadget here:
Affectionately known an an analog water pressure switch
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fill 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
May 28, 2011 | Whirlpool Washing Machines
Hi - my washer keeps displaying the f35 code and stops - i then cant unlock or cancel i have to unplug it - seems as though there are no repairman who know what this is - can you tell me what i should do...
The F-35 on some models means:
WASH CYCLE)
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
Check drain pump.
Under $100
Item 20
W10156252
May 02, 2011 | Washing Machines
Error code f35
F35 (on some models)
WASH CYCLE)
Check drain pump.
Apr 19, 2011 | Kenmore Elite HE5t Washer
I am getting a f-35 code on the washer ..what does that mean?
F35
Check if the air trap is not blocked.
WASH CYCLE)
Check drain pump.
Item 20
$86
Mar 17, 2011 | Kenmore HE2 Plus Front Load Washer
Often get an error code "F-35" and or "SUD" on my duet WFW9500TC01 Bill Selby
From my notes:F35
WASH CYCLE)
Check drain pump.
Item 20
What else have I got let's see:
$86
Could just be sediment in the tub.
Blow out the tubing before you order anything.
Make sure the hose is tight.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool deut steam washer Model W10133484A and I got a F35 error
The recommendation is to change this part:
F-35: Analog switch/water level failure.
Item 20
$86
F35
WASH CYCLE)
Check drain pump.
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag washer said suds then f 35. what does it mean do I need it repair?
Some F-35 notes:
F35: ANALOG PRESSURE SENSOR FAILURE
WASH CYCLE)
Item 20
$86:
Keep in mind if too much detergent was used:
Check drain pump.
Jan 04, 2011 | Washing Machines
Hi, My washer does not do the final spin.....Everything else seems to work except the final fast spin. Is there anything i can do?
Stop using so much soap? These newer washer must use a slight amount of HE soap. Any other thing will cause motor over amping, burn up sensors, and cause the control to work overtime trying to remedy the problem. F35
WASH CYCLE)
Check drain pump.
More Here
Dec 29, 2010 | Whirlpool Washing Machines
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
and it will try to spin or drain again.
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool sport will not drain, 5d code has appeared. what can we do
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
• If too much detergent was used:
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE WBVH6240F Front Load Washer Logo
180 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
