Question about Gateway Computers & Internet
MY WIRELESS MOUSE DOES NOT WORK,EVEN WITH NEW BATTERIES PLEASE SEND ME INSTRUCTIONS WITH DIAGRAM
  • 114 Answers
Usally on the wireless receiver there is a button (may be recessed that you press on the receiver and then the mouse to sync them on the same frequency.
Posted on Aug 18, 2008
How to setup ge 99916 wireless mouse
Instructions
    • 1Hold the mouse in your hand, press down on the battery compartment cover (the back of the mouse) then slide it off.
    • 2 Insert two AAA batteries into the mouse. Make sure the positive and negative terminals match up with the diagrams inside the battery compartment.
    • 3
    • Replace the battery compartment cover.
    • 4 Connect the USB receiver to a USB port on the computer. The computer will acknowledge that a new device has been installed and you will be prompted to install the software.
    • 5 Insert the software installation disc into the optical drive. Follow the instructions provided by the installation wizard to install the software.
    • 6 Press the link button on the receiver, then turn the mouse over and press the link button on the mouse. The mouse is ready for use.
Jun 07, 2014 | GE Wireless Optical Mouse
My wireless mouse has quit working. I'm guessing I need a new battery. However, I can't figure out how to even find the battery, let alone change it! How do I do that????
Cutting down on the number of wires that must be tolerated in a work station adds to maneuverability and ease of location. For all their convenience, though, wireless accessories bring with them a number of issues not present in their wired counterparts, most significantly battery change.
Instructions
    • 1 Turn off the mouse.
    • 2 Remove the top of the top of the battery compartment. The button that releases it is located toward the rear of the mouse.
    • 3 Remove the old battery and place the new one in its place. Replace the cover and turn the mouse back on.
Read more: How to Replace the Batteries in an HP Wireless Mouse ' eHow.com http://www.ehow.com/how_6947071_replace-batteries-hp-wireless-mouse.html#ixzz1LpG7oNYf
May 09, 2011 | HP Wireless Optical Mouse
I CAN NOT GET MY WIRELESS MOUSE TO WORK ON MY COMPUTER,,IT JUST RESENTLY STOPPED WORKING,,AND I HAVE PUT IN NEW BATTERIES,,CAN YOU PLEASE GIVE ME SOME SUGGESTIONS
Silly question for me for you -- are the batteries in correctly? Have you tested the batteries to be sure BOTH are up to 1.6 or more volts with a voltmeter? Even new unpened battery packs may be short on charge and not have enough juice within them...
If the above is not the issue, try the receiver of the wireless mouse, it may not be fully engaged.
Jan 05, 2011 | Logitech Wireless Access Duo Optical...
The "mouse" on my Hp Pavillion laptop stopped working last night---it will not move the cursor. Can I fix this and if so, please explain in basic layman's terms so I can understand the instructions?
Is this a wireless mouse, or a wired one? If it is wired, there could be 1) so much dirt between the ball and the contacts inside the mouse housing that it won't move (usually there is a way to remove the ball and use tweezers to try and remove all the accumulated stuff); 2) the connection (plug) could have worked loose. Pull the plug out, reinsert it, and reboot. 3) the cord could have a bend or been steppedon and have a poor or no connection. A new mouse is in order. If it is a wireless mouse, batteries are the probable culprit. We put new rechargeable batteries in less than a week ago in ours, and even though our mouse goes in a charger when we are not using it, it would not work until I put new rechargeable batteries in. Remember - even new things can be bad.
Aug 13, 2010 | HP Computers & Internet
Wireless optical mouse (DELL) doesnt work on my windows 7 system
mcdevito75 here, The optical mouse should have instructions, or you can type in search from home page up-date drivers.
Jun 25, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I cannot get it to work or even turn on have installed new batteries
mcdevito75 here, Double check Battery installation, try another set of new batteries. If the mouse was originally programed for the computer you may have to reprogram it. Refer to the optical mouse instruction booklet.
Jun 23, 2010 | Microsoft Wireless Optical Desktop Comfort...
My Dynex Wireless Optical Mouse just stopped working
If the mouse light is not turning ON even though you have new batteries and the mouse is turned on, then you need to contact the manufacturer for RMA.
Thank you!
Dec 22, 2009 | Dynex Wireless Optical Mouse
Toshiba Wireless Mouse (PA3706E) not working
just install new battery and press the conncet button in mouse .
Dec 18, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Advent wireless mouse wont work
ya u need the battery...................
if it dosent work even then ...........
and u r using window's then check wheter your configuration is enabeled........
if it is not enabeled enable it .and now it would work
Feb 01, 2009 | Computers & Internet
I have a Wireless Mouse 5000.
Is this a Microsoft Wireless 5000 Mouse? The battery plate should be on the bottom of the mouse to take off to put in the batteries, similiar to a TV remote contoller. And it can be latched pretty tight.
Included a Youtube video of someone taking the battery out of his mouse.
Jan 29, 2009 | Microsoft Wireless Laser Mouse 5000
Computers & Internet Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
