Question about Toshiba 27DF46 27" TV
Toshiba 27df46 i just received a tv from my church and it is a toshiba 27df46 27" tv. It says" please wait, thank you for your patience". I wait and nothing, Help please? Thanks.
  • derbacher Dec 08, 2008
    My sister's TV now has the exact same problem, a screen that says "Please wait...thank you for your patience". Prior to that she had intermittent audio drop out. Even her local TV repairman is stumped. Anyone with a possible solution?
    Thanks
    Bob
I have the exact same problem. i used to be able to turn it on and off but that does not work any more. hope someone has an answer for this.
Posted on Aug 18, 2008
Why won't my toshiba 27df46 come on quickly?
Leaky or blown capacitors, probably in the power supply board.
If your not competent get someone who is as there are high voltages inside even when the tv is off or not working
Aug 01, 2014 | Toshiba 27DF46 27" TV
I Have a Toshiba 27DF46 The Picture is shifted to the right about 3 inches or so. other than that the picture is fine but I can't see the right edge on the picture. Any thoughts
Try going into the picture settings in the options. Many Toshiba TVs have the option to move the picture up, down, left, and right. See if you are able to position the TV to the left more.
Also, see if there is a reset button in the options. A setting may have been switched that caused this.
Mar 02, 2011 | Toshiba 27DF46 27" TV
My toshiba model 27df46 won't turn on
Please check the fuse for blown and replace if needed
Jan 27, 2011 | Toshiba 27DF46 27" TV
Toshiba 27DF46 27" TV started only turning on
Bad solder connections on an older TV is common. Check all your solder grounds on anything mounted on heatsinks. The other thing is bad capacitors. Always suspect the 160 volt to 250 volt at 1 MF, 2.2Mf or 4.7Mf for being bad. This is true for many repairs for any brand of TV.
Dec 15, 2010 | Toshiba 27DF46 27" TV
No power or red led fuse good .toshiba 27df46
Hello Hloggins, hi, your power supply is not producing the pulse needed to start the switching. check for the IC on the oscillator part of the power supply, you need an Oscilloscope to test this. if there is no scope. i suggest you replace the IC.
May 20, 2010 | Toshiba 27DF46 27" TV
I just received a tv from my church and it is a toshiba 27df46 27" tv. It says" please wait, thank you for your patience". I wait and nothing, Help please? Thanks.
The set is trying to auto program the available channels and it can't find any because since the change from analog to digital [FEB 2009] broadcasting requires a "converter box" to translate the digital signal back to analog. Check around and see if you can find a converter box. They were available for $20 with a coupon, maybe they still are. Try an electronics shop or dealer for that info.
Apr 16, 2010 | Toshiba 27DF46 27" TV
Toshiba 27DF46 27" TV Logo
360 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
