Question about Epson Stylus R380 InkJet Photo Printer
Mac OS 10.5 Leopard
Since upgrading to Leopard I can not print CD/DVDs. Software used during problem: EPSON Print CD Version 1.4.0A I get the following message.
The EPSON printer driver dealing with CD printing is not installed.
I have reinstalled the EPSON Print CD software and drivers but still get
the same message. Any solutions?
I'm having the same problem as everyone else. When I try to print a CD, I'm told "The Epson printer driver dealing with CD printing is not installed," even though it is. I've tried "update printer information" and it doesn't work. I've tried several other suggestions I found online, and none have worked. Is there any solution??? MollyIreland This is frustrating.  I use this program to label the DVD's that I output for my work.  It worked fine under "Tiger".  I still have the Tiger OS hard drive as I was working with it, and have to startup using that disc in order to use Print CD.  It's not ideal.
Do those drivers "dealing with CD printing" that are "not" installed exist somewhere in my Tiger disc, that I can copy over to my Leopard disk?
  • javalvarez Aug 18, 2008
    thanks for the quick response, but what does "...not an easy task" mean?  is it possible, just difficult?  is there a solution out there? Like I said, I have a working "Tiger" version of my startup disk that Epson Print CD works on.  Would you know the specific files to try and copy over to my "Leopard" system?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Two issues here..
compatibility of Epson with Leopard..and also the drivers will need to be postscript compatible..not an easy task.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
  • Patrique Davenporte Aug 19, 2008
    well..that's the trick..the Tiger to Leapord leap is not that simple. are you using Leapord? if that's the case, you'll need a new set of drivers for more than the printer..this is a major upgrade to the mac OS
My Epson perfection 3490 photo scanner doesn't work on leopard. It worked fine on tiger. Do I need to download new software? The CD that came with my scanner says it is for Mac 10.2 to 10.4.
I googled Epson support and found the answer. Here it is:
Macintosh Leopard Support Contact Supportrightmenudottedline.gif apple_leopard_logo.jpg
Welcome to Macintosh OS X 10.5 Leopard support for Epson products. Here you can find out how to get drivers and other Epson software for your Epson product that work with Macintosh OS X 10.5.
Check your Epson product CD to see if it already contains Macintosh OS X 10.5 drivers. If the CD indicates support for Macintosh OS X 10.5, follow the instructions that came with your Epson product to install your drivers and other software.
If your CD does not list OS X 10.5 Leopard, follow the Step-by-Step Instructions below.
View our Macintosh OS X 10.5 Leopard FAQs.
Jan 20, 2010 | Epson Perfection 3490 PHOTO Flatbed...
I have upgrades to Snow Leopard on my iMac and cannot access the printer commands to cheque the printer heads, and ink levels.
You can find useful information on site? http://www.epson.com/cgi-bin/Store/support/SupportSnowLeopard.jsp Mac OS X Snow Leopard Support Contact Support rightmenudottedline.gif snow_leopard_logo_sm2.jpg Welcome to Mac OS X Snow Leopard v10.6 support for Epson products. Here you can find out how to get drivers and other Epson software for your Epson product that work with Mac OS X Snow Leopard v10.6.
Check your Epson product CD to see if it already contains Macintosh OS X 10.6 drivers. If the CD indicates support for Macintosh OS X 10.6, follow the instructions that came with your Epson product to install your drivers and other software.
If your Epson CD does not indicate support for OS X 10.6, DO NOT INSERT YOUR EPSON PRODUCT SOFTWARE CD IN YOUR SNOW LEOPARD COMPUTER. Follow the step-by-step instructions below to obtain the latest software and utilities for your Epson product as they may be needed for this new operating system.
Good Luck.
Nov 03, 2009 | Epson Stylus Color 777 InkJet Printer
Mac OS 10.5 Leopard
you need to install Epson Easy Print too
Jan 15, 2009 | Epson Stylus Photo 2100 InkJet Printer
Mac OS 10.5 Leopard
As per someone elses post here:
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Mac OS 10.5 Leopard
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
Jul 27, 2008 | Epson Stylus Photo R1800 InkJet Printer
New Epson RX595 won't print
Apparently the latest software doesn't work with Leopard 10.5.2. I uninstalled the Epson software and installed the earlier version [driver version 3.88] that come on the Installer CD with the printer. Printing now works.
May 18, 2008 | Epson RX595 Photo All-In-One Printer
Epson Print CD update needed
LINK to print cd mac version 1.6aE (it's Epsons Russian website, don't worry - the software is in English!)
not sure if it suits R200 if not then
see my other post here for more info
Jan 12, 2008 | Epson Stylus Photo R200 InkJet Printer
Mac OS 10.5 Leopard
Nov 09, 2007 | Epson Stylus Photo R1800 InkJet Printer
Mac OS 10.5 Leopard
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Nov 08, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus R380 InkJet Photo Printer Logo
248 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
