Question about Sewing Machines
Brother bobbin tread will not pick up
I have a brother XL-3100 and when I try to sew the bobbin thread will not pick up. No thread at all is in the clothing ive just sewn. I have oiled it , rewound bobbin and changed needles. This is the first time i have used this machine (or any in last 15years) so i need help to know what im doing wrong or just haw to fix it.. Thank YOU HW
PS THE FRONT OF MACHINE SAYS ITS A BROTHER XL-3100, but this sight says this is not a valid product so i had to pick a difrent one to beable to submitte my question, again thank you.. I can't make my bobbin thread work on a Brother model XL-3100 seral# U13103
882-236
FOB132977
A flat triangle slightly curved metal plate is seperated from bobbin support, is this correct or is it broken? If it is broken what is the replacement part number and cost? I am in need of a operators & technical service manual for this unit including a Singer Stylist 834 serial #91278495. I would appreciate this information buy the way my Dad is a retired BioMedical Engineer. I know he could us this information when I ask him to fix it,
SOURCE: brother bobbin tread will not pick up
when i sew the thread keeps cutting help
Posted on Aug 14, 2008
Zenqi
  • 208 Answers
SOURCE: I have a Singer Stylist 834, have rethreaded and
It sounds like your machine has a broken vertical shaft gear.
Open the slide plate and, while turning the handwheel, look to see if the hook is turning under the bobbin case. If not, take it to a repair person and it should cost around $100 to replace the gear.
Posted on Oct 01, 2009
SOURCE: Free manual for singer stylist 834
go to website
diplodocs.com
on the page go to the right side, there are alphebet letters,,go down to S & click on the name singer
it will take you to the next page
go down to box that says---most common searches
click on your sewing machine number-it there because I looked for it
it will take you to another page answer the questions about your sewing machine & then you can download the pdf file for free
Posted on Aug 05, 2010
I have the same problem with the same machine!!! Did you ever find the solution?
Posted on Aug 13, 2010
hazelgrace
  • 340 Answers
SOURCE: do you prefer the singer
Here's a review for the 834.
http://zigzaggers.typepad.com/zigzaggers/2008/07/singer-stylist-834.html
Although it mentions you cannot raise and lower the feed dogs, you can change the throat plate to cover the feed dogs when you don't want to use them.
I couldn't find any reviews for the 518. I think the higher the number, the newer the machine although I may be wrong about that! I have a Singer Stylist 416.
I would look at how easy and expensive it is to get replacement parts for both machines before making your choice.
This is a good site for Singer Stylist parts. http://www.tandtrepair.com/index.html
Why don't you email the guy who runs it and ask him what his preference would be?
Hope this helps, Hazel
Posted on Aug 30, 2010
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
How do I fix the stitching on my Brother XL-3010?
Your tension sounds far too loose. Or your needle is blunt.
Jun 25, 2015 | Brother Sewing Machines
Why Doesn't my sewing machine want to pick up the bobbin thread correctly?
if the bobbin case isn't turning properly are you sure you it in right.
Hold the lever on it out, slide the case on the spindle all the way and then release the lever. Also try a different length needle, it may be to long to allow a uniform stitch
Jul 12, 2014 | Brother CE8080PRW Limited Edition Project...
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
I am trying to use a twin needle, however, every time I begin sewing the machine makes a very unhappy sound as though the needle is being blocked as it tries to pick up the bobbin thread. I have tried ...
check to see if the twin needle are damaged
check the bobbin & make sure the bobbin case is thread correctly
needle & thread may not be compatable
here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 01, 2010 | Brother XL-2600I
Not sure if i have put bobbin back in correctly, I have an old janome sewing machine. Also I havent used a machine for about 10 years, trying to remember.
with the brother its Pretty easy. you drop the bobbin in with the thread heading counter clockwise take your thread around the feed guide in a Clock wise manner then turn your knob it should pick the tread up fairly easily
Apr 07, 2009 | Brother XL3750 Mechanical Sewing Machine
My Brother PE 150 will not pick up bobbin thread. I changed needles cleaned it etc. nothing helps.
My pe-150 embrodery machine is not grabing the tread right since I changed the needle out it keeps promping me to check my threading
Sep 07, 2008 | Brother PE-150V Computerized Sewing...
Jul 29, 2008 | Brother XL-3500
Sewing Machines Logo
158 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
