Question about NEC Lands Phones
We have a NEC DX2NA-16BTXH-LC2 (124i 384i)Telephone system One telephone was not used properly and has some programming on it that has locked up the system. We tried to delete all programs without luck. We need the code to erase all programming.
SOURCE: change the answering machine message
CAN ANYONE TELL ME HOW TO CAHNGE THE GREETING ON MY M7310 NORSTAR PHONE
Posted on Nov 03, 2008
SOURCE: NEC DTU-8-1 telephone system
Press Feature, 69, then feature again. The light will go off.
Posted on Apr 16, 2009
consultel1
  • 860 Answers
SOURCE: I need a user manual for an older phone and can't
http://www.wedophones.com/Manuals/NEC/i-series%20multibutton%20phone%20feature%
Posted on Dec 10, 2009
BILLatNASA
  • 3 Answers
SOURCE: Have NEC D term 80 phone without manual
The manual is here.
NEC doesn't call it the "Dterm 80 manual," but that's it. It's titled "Electra Elite IPK II Multiline Telephone User Guide."
Posted on Jan 24, 2011
SOURCE: We have a 92573 NEC
http://phone.manualsonline.com/manuals/mfg/nec_display_solutions/92573_1line.html
Hi please find above a link for your user manual. This is about the best I can do.
Try removing the phone from wall & telephone jack, wait say 5 mins, now reconnect it all back up.
Then using the manual and working from step ONE.. work through the setup steps FROM THE BEGINNING, I know it's a pain but...just do it..lol.. and I am sure you will prevail, usually it is a simple wrong or miss-step that can muck things up... so just carefully and slowly work through the settings and hopefully you will prevail
However IF after you have done so, and you are sure that you are right in what you have done, then you may indeed have a faulty instrument, of course the ONLY way to eliminate this is by substitution, with a "Known good" unit.and try that one in it's place.
But often before I consign things to the "bin" I will often get an offsider to do exactly what i have done, IE: Re-setup the device, sometimes, they will interpret things differently and may see a misstep or mistake, or step that has been made, that one may have missed, remember the object is to get it all going again, and it doesn't matter how it gets fixed.
Posted on Mar 17, 2011
Light still blinking after clearing voicemail on nec phone system
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Nov 30, 2012 | NEC Electra Elite DTU 16D-2 Corded Phone
User manual for 124i/384i telephones
Check in NEC Site or this link NEC 28i / 124i / 384i Telephone System User Guide
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 14, 2011 | Lands Phones
I have aN NEC DX2NA and the message waiting light keeps flashing but there is no message
The message waiting light was probably turned on by a co-worker by mistake. That type of telephone set was used on 124i systems among others. If thats the case, to turn off the message waiting lamp press your call1 button followed by 873, press the spk key to hang up. Hopefully that takes care of the problem.
Sep 10, 2009 | Lands Phones
Office NEC phone to be used at Home
This phone is a proprietory digital phone that only works with a KSU. You would need an IPK or Elite phone system to make it work. You would also need to program it. This is a business office system and that phone will not work unless it is plugged into the system.
Feb 05, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Jan 06, 2009 | NEC Electra Professional ETW-16DC-2
Directory Button need programmed to display caller ID
We would need to know the phone system type you are trying to fix. It is the box where all the wiring is, usually a telephone closet or server room. Let us know and we can help.
Dec 31, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
How do I program my NEC IP2AT telephone system.
buy a phone that has an answering machine built in .PROBLEM SOLVED . you just plug in to elec and the phone jack
Sep 30, 2017 | Lands Phones
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Jun 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
123 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
