Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Door seal replacement
How did you manage to get the inner doors joint off? I have removed the front easily but am now stuck!!
Cheers,
Paul.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Should be held on by a sprung ring round it. prize it off with a screwdriver and pull the seal towards you.
Posted on Jan 27, 2009
Replace door seal
its quite easy on this machine,you can view a video on Espares.co.uk or remove front panel ,seven screws 4 top 3 bottom unclip wire on seal at front seal has two large clips to secure one outer and one inner, I find it best once the front panel is loose to unscrew the door interlock to fully remove cover once this is done you can see the workings and the exposed seal good luck.
Nov 02, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
Front door rubber seal
Fairly easy to do. It is held on with 2 wire rings, one on the outside edge of the seal when you open the door and when that is removed there is another one holding it to the outer drum. Removal of the lid may also help with removal of the inner ring. When refitting you press the lip of the seal over the outer drum edge and fit the retaining ring back and then do the same on the front where the door meets the seal. Just make sure the small drain holes in the seal are located at the bottom, best to look at the old one to see how it's fitted before you remove it.
Dec 27, 2012 | Electrolux Washing Machines
How to replace inner glass panel on Neff H7871 microwave
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
Oct 10, 2011 | Neff H7871 Convection/Microwave Oven
The drum on my wma 40 seems to go tight any ideas why
may have something stuck between the inner and outer drum...... socks tights and womens skimpies very easily slip down at the bottem door seal.... afraid the machine needs a total strip down if this is the case. remove the door and front panels, the drum has a front cover held on by a number of clips..... remove all clips take cover off....find said item and put back together shouldnt take more than an hour.. if it isnt that,.then rear bearing could be shot at,, sorry
cheers
Mar 24, 2011 | Hotpoint WMA40 Front Load Washer
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
Rubber seal damaged. needs to be replaced kenmore model 970-c44052-00 How do I remove sides to get at it?
there is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
Dec 06, 2009 | Kenmore 43142 Front Load Washer
Removing Door Trim
hi-- the inner door handle is tricky! it is held in by clips that SLIDE BACKWARDS!! apply a little inward pressure then slide the handle assembly back!!-- then you will have to remove the metal rod from the handle----------putting it back is the reverse.----cheers
Apr 18, 2009 | Hyundai Excel Cars & Trucks
Weather strip replacement
The door is filling with water? If this is the case then the best way to dry this up is to remove the inner door panel and dry the water up. With the inner panel off this good time to replace the seal. Please keep me info how you make out
Cheers
Aug 22, 2008 | 1986 Chevrolet Caprice
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
