Question about Insignia NS-DV2G MP3 Player
Repair my pc
Hey anyone can help me?Hi my name is jorge and i would like to know if the recovery cd is the same as the operating system bcz i don,t know if i can repair my pc with the recovery system,my pc is in blue,thank you.
  • 37 Answers
If the recovery disk came with the system yes it will have a copy of everything that came on the PC when you bought it if you upgraded th OS you will have to do a upgrade after you have used the recovery disk.
by using the recovery disk you will return every thing back to the factory so you will lose all your saved data, bookmarks, pic, and doc's.
Posted on Aug 24, 2008
It is looking for the windows automated system recovery disk and I have reistallation cd. how would I get this
You will need to create one.
Windows system errors, crashes and other problems may lead to a malfunctioning system or an operating system that doesn't load properly. You can create a Windows system-repair or automated recovery disc that contains tools for fixing the operating system. The CD you create will contain system-recovery options and tools like Windows' Startup Repair, System Restore and the Windows Memory Diagnostic tool.
Insert a CD into the CD/DVD-ROM drive. Click the "Start" button. Type "backup" in the search box and click the "Backup and Restore" search result entry. Select the "Create a System Repair Disc" option in the left column. Click "Yes" or "OK" if a user account control message appears. Click the "Drive" drop-down menu and select the name and letter of your CD/DVD drive. Press the "Create Disc" button. Wait for the progress bar to turn completely green and Windows to finish the repair disc. Click "Close" and then "OK" to exit the repair disc wizard. Hope this helps.
Jan 04, 2013 | Dell OPTIPLEX 745 PC Desktop
Software corrupt,can not format to pc
whichone is corrupted, Operating system(XP,Vista,Wim-7) or application software(Microsoft word,excel,powerpoint,adobe).If applicatin software try to reinstall from the same cd.If Operating system,put bootable cd(xp/vista/7) in cd drive and restart the system,then click press any key of the keyboard,then u can see some file checking,then press F8 key on keyboard,press on ESC key,(don't format ur data will loss)select on Leave the current....and enter give the folder name as C:\WINDOWS1 (depepends upon ur drive space-C:,D: etc..) then press enter,then go thru the instructions.
OR
mostly in all branded laptops Operating system Recovery Options is there.Restart then press F2 OR F8 keys.(in this case there is chance for data loss )
May 23, 2011 | Computers & Internet
Recently, I encountered a problem with my Asus EEE PC. I used the Recovery File within the Hard Disk by pressing F9 on the boot process, and I successfully restored my EEE PC to factory default. Now,...
Yes they should be the same. You should be able to reset the laptop to factory defaults using the provided recovery disk just the the system on your HDD. The reason they have both is because the HDD is much faster than an CD. The HDD recovery system also keeps track of required OS updates and will keep those so you don't have to go through hours of system updates in most cases.
May 09, 2011 | ASUS Computers & Internet
What should i do if my windows\system32\config\system is missing or corrupt
Hi
try to restore system or repair the windows
you can try so copy the folder from another good running windows
Apr 25, 2011 | Gateway 310X PC Desktop
Hi i cant get my recovery cd to work but i have used it befor. i have changed the boot bios like it says on cd sleeve to 1 cd rom. 2 hard drive. 3 floppy although it hasnt got a floppy drive, i put...
if u want to get recover ur system with the help of recovery cd then first of all if u have done first boot device cdrom on bios setup then restart ur system . while booting the system u have to continue press the 'enter' to boot from cd rome then ur system will boot with cd rom then u can get recovery.
Jan 15, 2011 | Computers & Internet
Gateway laptop reset
Gateway Direct systems went "media-less" back in September 2004. In the event of a system crash users could either 1) restore their systems from the Recovery Partition OR 2) from the backup media that they were prompted to create on first power-up -- which would provide them with up to 5 blank CD-R discs depending on their system's configuration.
On the factory load of the hard drive, the recovery partition will not contain operating system files. It only contains application and driver files.
The first time the recovery partition is used, it prompts the user to insert their System Recovery CD/DVD to copy files from the CD to the recovery partition.
The Drivers and Applications CD is not bootable and does not contain Operating System files.
The System Recovery CD/DVD is bootable but does not contain any application or driver files.
If the end-user erases the hard drive and restores the computer using the System Recovery CD/DVD and an Applications and Drivers CD, the recovery partition is not recreated.
This means that you will need the operating system restore disc FIRST then the recovery partition will work for you
Mar 14, 2010 | Computers & Internet
Bootmgr Missing
Hi, you be to be sure that your unit of this CD-DVD working correctly, of being like that, must check that both CD's are well-read correctly, once overcome this, you can to install without problems the operating system Vista to your equipment
Jan 20, 2009 | Computers & Internet
Server2003 enterprize edition
Hey There,
You are getting this problem b'cause loss of ur system file i.e. "CONFIG.SYS", Which loads ur initial files and drivers needs to start ur operating System.
You must follow the steps given below to start repairing ur System:
1. Insert the Bootable OS Disk into ur CD/DVD-ROM.
2 Reboot ur System.
3. The system will prompt You to "Press any key to boot from CD".
4. Press Any key.
5. Now the system will load all initial files and hardware driver.
6. After loading driver and files, OS will ask you for acceptence with their Terms and Conditions.
7. You must Agree with terms and condition. press F8 key for accepting terms n conditions.
8. After step 7, OS will search for the partition of ur Previously installed OS. If you have two operating system then it will show two Partitions with their name and drive letters. (You must remember the drive letter where ur OS is installed that u want to repair)
9. Now Leave that option as it is. And press Escape key.
10. Now You'll be able to see all those partitions you have on ur Hard disk, with their drive letter, Name and free space.
11. Select the partition of OS that u wanted to Repair, By Scrolling Arrow Keys. (Be carefull while selecting the Partition. If you select wrong partition then You wont be able to repair ur OS)
12. And then Press "R" Key from ur Keyboard.
13. Now OS Will search for the partition you have specified.
14 It will Delete Old system files and Copy New files (Note: You won't loose any data, Previously you had saved on ur boot partition).
15. After Step 14, OS will save the configuration and Will Reboot itself.
16. Again You will be asked for "press any key to boot from CD". Don't Press Any key at this step.
17. Now follow the wizard n specify correct information you will be asked.
18. It will take about 20 to 30 minutes to Repair ur OS.
Note: These Steps are not valid if you are using Windows Vista
Romy_Dec
Jul 30, 2008 | Microsoft Windows Server Standard 2003 for...
"Improper Image in use" Error during system recovery
There are several ways you can get a repair man...
1).Find and Compare prices on repair man at Smarter.com.
2).Find repair man at Great Prices at pronto.com
3).Schedule a repair online at sears.com.
4).www.repairman.org
5).look in a phone book
Dec 08, 2007 | Sony VAIO PCV-W20 PC Desktop
Insignia NS-DV2G MP3 Player Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
