Question about Sharp AL 1631 Copier
Drum catridge codes
Hi I have a real problem, I had a copier in my country but dont sell anymore the drum cartrige for my copier, did you now where can I find the code to unblock the drum cartridge? becouse the salesman tell me when I buy it he give me those codes and never did, help please I have 6 mo whith my copy machine and I my country dont sell those parts
  • yumagrev Aug 19, 2008
    Hi thanks for the post just I dont now how can I ge into the service mode, you say press # and C on the keyboard, but I dont find the # button, and Im bery greateful if you put me on touch whit a suplyer on US
  • Sharp Master
  • 2,794 Answers
There is a drum counter clear that is service code 24-07.
Eventually your'e going to have to replace the drum. I can put you in touch with someone in the U.S. that can get you the parts you need.
To get into the service mode press #*C* on your copier keyboard.
Press 24 and the green key.
Press 7 and the green key.
Posted on Aug 18, 2008
Xerox 7335 Yellow Drum catridge did not shows.. Catridge is perfect but did'nt shows...
Make sure deal has been removed pull out press cancel 30 seconds...power off on the put back in
Jun 28, 2016 | Miscellaneous
chek the catridge and drum
it may help u...
May 20, 2013 | Brother HL-5240 Laser Printer
The printings in my hp laserjet 1010 keep appearing with a white band at the right side of the page, i've tried to reinstall the toner but still appears...can you help me guys? please!
Go to paint shoot black colord print page, while printing half page switch off the printer remove cartrige gently, check on catridge drum surface is there any while patch in black image on drum ? if yes *** open laser scanner assembly clean the reflect mirror with ear buds gently fix it back then try once..****check image on paper is there any white band? id no replace teflon sleeve/fuser.*****If white patch is not in image clean/replace the transfer roller. best of luck..
Sep 12, 2011 | HP LaserJet 1012 Printer
Paper has jammed rinter
paper jam is of two types.1.while spolling half paper will come out tom tray.remain jammed in rollers.This can solve by switching the printer power off and remove toner catridge from printer.Then power on the printer.lift the top rollers cover and reset as it is.The paper will come out without any difficult.2.Paper jam inside the toner catridge by rolling itself to drum.Switch off the printer power.Remove toner catridge from priter.Unscrew the toner catridge cover screws.remove drum from toner catridge .Utmost care should be taken while removing jammed paper from drum.Reassemble as it is and set.
mohanraojagan@yahoo.com
Nov 07, 2010 | Brother HL 5170DN Laser Printer
When I refilled the printer catridge, I can not print it anymore. The message is "change catridge invalid refill" What should I do with this problem? or I can't fix it.
did you replace the IC count chip.Its made on the front of the drum and it resets the drum back to zero.Mfg dose this so you will half to buy OEM supplys only.
Aug 12, 2010 | Lexmark T630 Laser Printer
The problem is the drum unit & toner catridge the paper stock inside the drum unit & toner catridge..
I understand the paper is stuck inside the drum unit and toner cartridge. Great. Take the drum unit out, separate the toner cartridge, and since you see paper, pull it out carefully with the tweezers. Do not touch the drum or the toner cartridge part.
Oct 12, 2009 | Office Equipment & Supplies
Changing Developer on E-Studio 150
The developer you need to purchase is 1620 , and the drum unit also the 1620, you can see this number in the toner catridge itself. or in the toner catridge box. Regd. the 161 you need to purchase the products name 1620 number and the concerned part like developer, drum, toner, some gears etc.
Aug 19, 2008 | Toshiba e-Studio 161 Copier Copier
My drum was exposed to light it now prints black sport on the paper
Check another catridge.If your printout is ok,then repalce your catridge drum.If u are refilling your catridge don't expose it to light.
Jul 17, 2008 | Kyocera Office Equipment & Supplies
HP Laser Jet 1100
Ok fine do you want to refill the old one or you want to take the catridge from the printer if you need Manule i can give you the link where you can download the manule the use it
Thank you
Mar 04, 2008 | HP LaserJet 1100 Printer
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
