Question about Sharp Microwave Ovens
Sharp Carousel Over the Range Microwave R-1470 Quite working...has power and control panel works, timer will count down but microwave won't run.
  • Anonymous Mar 19, 2014
    Control panel does not work
  • Anonymous Mar 28, 2014
    This wonderful old microwave stopped working all of a sudden. The control panel works -- that is, the timer counts down, the lights work, but the motor does not come. However, when I slightly lifted the door while the timer was counting down, the motor did engage briefly leading me to believe the problem, is in the switch that is engaged when the door closes.
  • Sharp Master
  • 9,098 Answers
When you hit Start, does the oven lamp come on but not the fan or turntable?
That would be a problem with the secondary (bottom) door interlock switch or its mount.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Aug 21, 2008
Have a Sharp Carousel R-309YW but seems like there is a random delay time period BEFORE the sound, platter turns, and microwave works. The light comes on, and timer counts down however. Thank you!
Bottom door switch trouble or its mount is loose, misaligned, or broken.
See my help file: http://www.microwavecontrol.com/doorsw.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 01, 2017 | Sharp Microwave Ovens
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
Sharp carousel R1472A Over the range microwave. Night light on microwave that shines down on range top will not work, Help! Yes, has two new bulbs.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Yours is similar to this one:
Apr 25, 2011 | Sharp Microwave Ovens
I have a Sharp Carousel Microwave Model R-1511. There is power to the unit, but when I try to operate, the blower doesn't work, the carousel doesn't turn, and there's no heat (the timer does count down...
Can you remove the timer panel?? Do you see screws to do that?? Make sure the unit is unplugged first. Then once inside check the door switches and the wires to them. Look for a switch that doesn't click when you push the plunger on the top. Or a browned wire terminal to the switch. That is where your problem will be.
Oct 20, 2017 | Sharp R-1511 Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Microwave Ovens Logo
151 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
