Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader making alot of noise
Saturday while washing I heard a pop and the the washer began to make a noise. My hand husband took a look at it and after pulling the gray rubber seal back in the opening to the front notice that a with ring that supports metal drum is broken. I called repair man for monday but am curious about coast to fix it ! I dont want to be taken to the bank. One repair man who never looked at it said front loads are expensive to repair?
  • 5,911 Answers
Front loaders can be expensive to repair. The labor costs can rack up and the parts aren't always the cheapest. However, the little metal retaining ring can be ordered on line at searspartsdirect.com for a very reasonable price. Look under the "Door and Latch Parts" heading for item number 14 (part number 8182211). If you are talking about the rear clamp that attaches to the wash tub, look for item number 6 (part number 8182210). Neither one of these parts are expensive and the following link gives you step-by-step instructions on how to replace/repair the bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you want to save yourself the trouble and expense of having someone else do this job for you, take a look at the link and review the cost of your replacement parts. This job is not difficult and you can save yourself from an expensive repair job. I have performed this job in the past and usually runs over $200 with parts (with the bellow being replaced) and labor charges. If the rubber bellow is in good shape, all you need is the clamps. I would doublecheck, however, the clamp(s) may have just come loose. All you might have to do it tighten them. I hope this helps you. Let me know if you need further assistance.
PS DO NOT over-tighten the inner bellow clamp. It can break the clamp and/or cause damage to the tub.
Posted on Aug 19, 2008
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load wfw9151yw, I've had it less than a year and the bearings are bad!! Where can I buy bearings? How long is the manufacturers warranty. And what does it cover?
I also had the very same problem with my Whirlpool front loader. This is a common problem and if you have this less then one year they should replace the parts for free. The reason I said parts is because they also had to replace the entire tub and some other parts as well. It took then almost three hours. Thank goodness I have an extended warrentee which I think you shouls also consider.
Whirlpool is a very reliable company and after reading what Ashley sent to you I don't think your going to have any problems.
I just want to mention something to you. If the washer makes noise it could be something else like a clogger drain pump which is easily serviced. The way to tell is to have the washer off and try spinning the tub with your hand if it makes noise then your up for the whole monti.
Good luck,
Marty
Nov 01, 2013 | Whirlpool Duet WFW9151YW 27" Front-Load...
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It makes alot of noise when its in the spin mode
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washing machine
you see plastic shavings??? thats part of the front tub assy, not a very fun part to change call a professionnal for that one. in the meantime id pop off the lower acess panel and make sure all 4 of the suspension rods are in place and not causing the tub to lay foward and rub
Oct 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like you have a board problem. If the machine is only 1 month old, you should really have a warranty agent look at it. You don't want to do anything that could void the warranty.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
178 people viewed this question
Dan Webster
Dan Webster
Sal De
