Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Tape shows last 5seconds of previous clip before recording next clip
Occasionally when I am getting ready to video tape the tape seems to go back to the last 5 seconds or so and starts playing. It's like I have hit the search button but I know I haven't. It doesn't happen all the time. usually i wait until it's done then start recording or shut the camcorder off and then turn it back on and record. I am on battery power while this happens. any suggestions why this is happening.
  • 4,234 Answers
I'm not familiar with your particular model, but many cameras of this type have a "quick review" function that allows you to see what was recorded for the last few seconds to verify that all is well. This is critical in broadcast situations where you only get one shot to get the video. This is a quick way to verify that all is working without having a blank gap in the recording caused by an inaccurate rew/play/stop/rec sequence.
Check the manual for this "review" function.
Dan
Posted on Aug 18, 2008
SOURCE:
AG-DVC30 "no tape in camera" error message
thats probly the cass in swicth
or a dirty sensor....
hope that will help..
Mar 01, 2010 | Panasonic AG-DVC30 Mini DV Digital...
C:32:23
This is a common problem with alot of Sony CamCorders...The solution is simple.....GIVE IT A WHACK!!!
Seriously, Take the battery off the device, Give the camera a smart "smack" on the tape side of the unit and power it back up.
works in 90% of cases!!!
Sep 22, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
My video camera won't record or play videos.
I have about 2 to 3 tapes that wont play on any of my cameras. I have lots of footage on each of them.
Dec 13, 2008 | Video Cameras
Blocks of noise
Don't know about the slow motion, but the noise is usually from dirty heads. Just like a cassette player it needs them cleaned periodically. Dip a Q-tip in rubbing alcohol and rub over the entire path the tape takes. You'll see a little block that actually reads the tape. Thats what you need to clean.
Make sure you eject the tape and remove the battery while the tape drive is open to clean it. Rubbing alcohol dries fast but give it an extra ten minutes and check it again.
Video recorder while the heads were dirty will not change however new video should be clean.
You may also have a bent tape carrier that is putting your video off track. It needs to be pushed or pulled to realign it.
It it's not the cause though, this can make playing back the earlier tapes more difficult since they will read and record in a slightly different part of the tape.
Jul 10, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Panasonic Video Recorder has stopped working
looks like some kind of sensor within the mechanical part, its seems like the mechanism doesnt return fully to its original point giving you these kind of malfunctions, I suggest to take it
to an authorized dealer for a complete check up & tune up
Apr 15, 2008 | Panasonic NV-HS1000 S-VHS VCR
Cannot play my recorded films
if the camera is not showing recently recorded clips then the problem is fith the recording system, but if you are not able to view the old recorded tapes the there may the simple defect of head getting dirty. a head cleaning tape would solve the problem
Feb 12, 2008 | Canon ZR300 Mini DV Digital Camcorder
Everything seems fine, but will not record.
buy a cleaning cassette and play three times and then try to record .
Feb 02, 2008 | JVC GR-D33US Mini DV Digital Camcorder
Video screen is scrambled
bad tapes ive seen it before ..buy a different brand brandnew ones and give it another go.
thats why other tapes are working.
Nov 11, 2007 | Sony Handycam DCR-TRV33 Mini DV Digital...
Incompatible Tape
try a cleaning tape first - best not to rewind the cleaning tape because it will put back the crud previously removed ? into your heads and guides ( last tape to play is prime suspect ) ; - - digital heads wear faster than analog so a new set of heads is next possibility but if the cleaning tape works . . . retire your library soon as possible .
Jul 26, 2007 | Panasonic PV-DV400 Mini DV Digital...
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
59 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
