Question about Vacuums
I received robot one week ago,it has stopped running,no power. It stopped in the middle of cleaning yesterday,I put it on the docking bay,but it is not powering up. no light when I push poer on,nosound,nothing. everything is plugged in properly.
    Problem Solver:
  • 6 Answers
Greetings from GoVaucum.com,
Just out of curiosity what type of Robot do you have?
Thanks,
Chris Jones
GoVacuum.com
Posted on Aug 18, 2008
SOURCE:
Why roomba clean for 2 minutes then returns to dock?
I suspect the battery is about dead. It keeps coming back for more power.
Run it away from it's charger, force it to run until it dies. Put it onto it's charger and let it charge a long time (Solid green light). Then run it again till it dies and repeat. This will perhaps force the battery to develop a longer memory
May 09, 2014 | iRobot Roomba 4210 Bagless Robotic Vacuum
Why does irobot dock without cleaning room?
How long does it run before docking? One to two hours is normal. 2 minutes means your battery is dying and it's coming back for more power.
How do I change schedule on Roomba
go to roomba.com when at there site go to customer care support then to pooduct resources then select a robot roomba,scooba,ect find your sereies 700,600 ect go to documents&manuals then to scheduling roomba then to viewing and deleting schedules follow the steps
Dec 18, 2012 | Roomba iRobot 560/561 Vacuum Cleaner...
My roomba 530 cleans just great, but it will not return to the docking station--it just stops in the middle of the floor without any warning. I push the dock button, etc. to no avail.
I sometimes have the same problem with my Roomba 530 (named Ethel). Make sure the signal transmittor on the docking station and the signal receiver on the top of the Roomba are clean. You can use a cloth or paper towel with a SMALL amount of window cleaner to run around both of these signal devices. I also like to clean the metal contacts on the station and the corresponding contacts on the bottom of the Roomba at the same time. This won't make a difference for the docking but it just assures that the vacuum will charge efficiently. If this doesn't work, you might need to have the unit cleaned professionally unless you feel comfortable about taking the unit apart and cleaning it yourself. I did this and Ethel has worked fine ever since!
If this helps, please come back and rate my suggestion!
Jun 06, 2011 | iRobot Roomba 530 Robotic Vacuum
I installed a new battery in my Roomba 540. It charges and runs directly with power cord but will not charge on dock. When I push the dock button, it acts like it "sees" the dock and approaches it and even...
Try to clean the metal contacts in the dock and in the roomba.
If you have a multimeter, measure the DC voltage on the dock contacts. If it's around zero volts, then you have a faulty dock.
Hope it helped.
Jan 16, 2018 | Roomba Robotic Floor Bagless Vacuum
I unplugged the docking station and now does not work
I actually had the same issue with mine.. it was 6 years old and just stopped finding the docking station. Also wouldnt take a charge. So I just eliminated the docking station. The stations power cord will charge the unit. Hope this helps.
Sep 12, 2009 | Roomba Robotic Floor Bagless Vacuum
IRobot 530 charges intermittently
Reset the Roomba: hold down "spot" and "dock/demo" for fifteen seconds, then release and listen for the tune. Then charge the Roomba overnight. The next time you run it, the unit should run longer. If not, call support and let them know you may have a battery problem. 1-877-855-8593 (I strongly encourage you to have the Roomba with you if you call.)
Aug 30, 2009 | iRobot Roomba 530 Robotic Vacuum
4210 and 4230 won't charge-new batteries.
I've been having the same problem myself. The charger is apparently built into the roomba main board. From what I've read there are two MOSFETs U2 & U4 that can go out and require replacement to fix the problem. More info here
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=3909
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
My Roomba does not want to dock
Need more info.
Does the unit go into search mode? "SPOT & CLEAN" flashing? It actually tries to search?
Do you have another roomba to test your dock on to see if IT will dock? If it tries but just cant, then either the dock transmitter, or the roombas receiver is dead. (The round antennae thingys on the dock and the bumper) replace these would be the first point.
Jan 21, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
