Question about Gaggia Baby Espresso Machine
Lack of water pressure - Gaggia Baby Espresso Machine
    Sergeant:
  • Gaggia Expert
  • 223 Answers
Try Descaling your machine with Descaling solution. Your group head may be clogged with calcium deposits which will cause a pressure loss.
If you need descaler you can purchase it at http://cerinicoffee.com/Dezcal_descaler_4pack.asp
Authorized Gaggia Service Center
Cerini Coffee Services
New York, USA
www.cerinicoffee.com
Posted on Sep 12, 2008
WHAT COMMON FAULT CAUSES THE PRESSURE WASHER TO CUT OUT WHEN PULLING THE SPRAY GUN TRIGGER
Lack of water preesue can cause this, how long is the hose to the washer, are there any kinks and what is your water pressure like generally.
If there are no kinks try shortening the water feed hose
Sep 13, 2014 | Garden
Karcher k3.00 lack of power
Are you using the same water supply as before when you had good pressure? Some house water lines have pressure reducers to protect your pipes and appliances. This can restrict the water flow and reduce the pressure the machine develops. If the flow surges (good, then weak, then good etc) you are not getting enough water to the pump. Try a larger diameter garden hose (5/8"). If you know where your water line enters the house, try the hose bib closest to it. Often times it is at street pressure instead of (reduced) house pressure.
Aug 03, 2014 | Karcher Garden
Lack of water
Is it filled with water? If yes, then the liquid level sensor has failed in the unit. This will happen normally, but does happen frequently if you have growth in the water reservoir. Call for service. Follow instruction in the manual about flushing the reservoir.
Feb 16, 2014 | MTN Gearsmith New 1500w Commercial...
Low water pressure
Water pressure problems can be caused by a number of different things.
First you should find out if anyone else in your area is having the same issue. If it is an issue with the water system in your area then you wont be the only one experiencing this.
The lack of water pressure could also be an issue with your homes plumbing.
Either way it can be an expensive fix. For city water pressure problems you may have to get a pressure pump in order to increase your water pressure
Oct 04, 2012 | Plumbing
Low presure
sometimes the water pressure from the house is insufficient, when it happened to me it would run weird. The water would come out in spurts because little water would come out of the water hose. You could try and lower the pressure on the machine to compensate for the lack of pressure going in, that's all I can think of.
Jan 21, 2012 | Karcher Garden
Lack of Hot water pressure
If its a tap refurde to, remove the head at the front of the tap and clean out the filter in front, if the houses warm water has low presure u must find ur presure redusing velve located on main cold feed to geyser and clean the cartrage out revit and ur presure must then be vine , let me know if that dosent help
May 28, 2010 | Danze & Single Handle Tub And Shower...
Lack of water pressure from gun
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up. Also, adjust the nozzle by turning it to increase pressure.
Apr 15, 2010 | Karcher PSI Electric Pressure Washer
Lower and upper spray arm will not turn
If the spray arm is not binding due to worn out plastic bushings, then it could be a lack of water pressure, because it is water pressure which makes the arm turn.
Give it a gentle tap in a clockwise direction,,does it spin easily?
If it does,,then it will be lack of water pressure that will be the cause.
Possible pump wear or failure.
Jan 30, 2009 | Maytag MDBE790 Built-in Dishwasher
Beeps eight times
Correct - lack of water pressure at the dishwasher, not the same as whether there is pressure from the line going to the dishwasher. There may be a clog or a valve that is closed.
Nov 21, 2007 | Fagor LFA-65 IT Dishwasher
Gaggia Baby Espresso Machine Logo
219 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
