Hisense PHD-4220 Television Logo
Posted on Aug 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No picture I have a magnovox dlp hdtv 50". we have sound but no picture and the lamp light is illuminated red. we have had this problem before and thought it was a cooling issue. we propped a fan up to the back of the tv and within a few minutes, the tv worked fine. Now that is not working. Hubby is thinking it is the lamp. I just want to make sure before I buy one. Please let me know. No picture but there is sound and the red light shows .i have not taken any step to resolve the problem.
Anonymous
Level 2:
  • Expert 113 Answers
  • Posted on Sep 27, 2008
Anonymous
Expert
Level 2:
Answers
113
Questions
Helped
75299
Points
270
This is your lamp and the fan was just a temporary solution that was keeping the lamp cool. If you pull the lamp out you will see that it has shattered from the heat.
Thanks.
Josh
2answers
1994 magnovox dosen't show picture and sound can it be fixed
yes it can be fix, are you seeing a indicator lamp that flashes if you see this flashing light try to check the lamp at the back of your tv or look for the manual and check the lamp if damage. if the lamp is damage try to replace it in replacing the lamp it has a proper procedure it is in the manual to just follow the instruction and your unit will work again.
2answers
How do you replace bulb in magnovox DLP?
Try website like You Tube.Type in ur tv model,make and projection lamp replacement.U will get a tutoring video how to replace the projection lamp.
Samsung 50" DLP No picture and very deep & lound vibrating sound. Red lights flashing,Sand By Temp. And Green lights flash Lamp.
Loud sound you are hearing is coming from your color wheel and has your Lamp ever been replaced? this set has 3 Fans they all must be running for set to operate correctly! Encompass Parts has Boards and Color Wheel But for Lamps Mats has them for 99.00 1-800-628-1118 and EC Parts 1-800-638-3328
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Power shut down, why?
Part Number 80.95C06.001
you can get this part from www.encompassparts.com
also i recommend to replace the lamp too
Part Number928137805390 lamp W/out cage
1helpful
No picture
Pull the front cover off at the bottom. You will see a panel which has to be removed using a screw driver. Inside you will see the lamp assembly. It is a removable box. The lamp can be changed out by just changing out the connections on the new lamp. Before you pull it though try reducing your picture size to 4:3 it helped us to get a little more life out of our lamp.
4helpful
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
2answers
RCA DLP 50" NO PICTURE
hoping it's just the lamp - removed it, and it had blown, broken glass and all!
Top Hisense Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
MrFixitSTTL
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
