I have a Canon MP 610 which has a paper jam, can you help
  • aileen_smith Aug 18, 2008
    Already tried that but thanks for the suggestion
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Sure..open up the back of the printer, and see if there's some paper stuck in there.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
  • Patrique Davenporte Aug 19, 2008
    ok..the paper jams only arise from a few options..
svenby
  • 66 Answers
SOURCE: canon pixma mp☺50 error 3
  • try this...........
  • Turn off the printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset eeprom). To disable the printer “Power” button to click again.
  • Posted on May 29, 2008
    • 523 Answers
    SOURCE: cannon pixma mp 610 printer paper feed making loud noise no feed
    Replace the pickup rollers and check the Gears if they become bad.
    Best Regards
    Posted on Mar 11, 2009
    SOURCE: knackered
    i was told this is a common problem on this model and was advised to return the printer to the shop were i purchased it from
    Posted on Apr 18, 2009
    SOURCE: Canon MP 510 paper jam
    I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
    Posted on Jun 18, 2009
    SOURCE: Instructions for settings on Canon MP-610 printer{ OK, HOME, ettc.
    What setting on the MP610 do I use to print on transparency sheets
    Posted on Jul 10, 2009
    MP 640 paper jam message that wont clear
    door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
    Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
    I have a Canon MP 210 with an E3 error message (paper jam) though there is NO paper jam. The paper feeder is spinning but doesn't grab the paper. Please help! Thank you, Robin
    I think there is a paper jam or something stuck in the sensor that is making it think there is a paper jam. It may be a very small piece of paper which you have missed. Look again.
    Jan 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
    My CAnon MP 610 has a service error 6A00. What is
    Hi
    Error 6A00
    The 6A00 is a Canon generic code for paper path jam.
    Solution 1:
    Move the printhead carriage back and forth a few times.
    Solution 2:
    Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
    Solution 3:
    Press the ink pads down in the purge unit.
    All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Apr 25, 2010 | Office Equipment & Supplies
    My canon mp 830 all-in-one printer says 6A00,
    no need to reset your printer, the things your should do is you just open the over at the back of your printer, then you can see a paper hang on, then please remove it, then try to print, if it does not work open also the tray which is your bond paper stored, just see if there is also a bond paper hang, then remove it, then print again, that the cause of paper jam
     Good Luck!!
     Nice
    Jul 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Apr 30, 2009 | Canon PIXMA MP510 All-In-One InkJet...
    Cannon pixma mp 610 printer paper feed making loud noise no feed
    Best Regards
    Mar 11, 2009 | Canon Office Equipment & Supplies
    I Have a problem with my canon MP 150 Printer
    From Canon Support: "Please be advised that if the MP 150 is displaying the letter E followed by number 3, this would indicate a paper jam. "
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=16981
    Jan 17, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    78 people viewed this question
    jasbo
    jasbo
