Receiver overload - Audio Players & Recorders
  • 5 more comments
  • mdscomputers Aug 18, 2008
    I have the same receiver with the exact same problem. Mine started after we had a storm and was plugged into a surge protector. All Three fuses inside are ok I'm thinking it may be the output transistors shorted but not sure. Each channel is on it's own plug in board and I wondered about removing one at a time to see if I could narrow it down to one channel but I don't know if that would work or not. Any idea's?
  • dhugh617 Nov 28, 2008
    My reciever has begun to display overload when playing CD's from my Sony CD/DVD player. I have to turn it off and it will reset but after a few minutes it went into overload. There is also a transformer like hum during operation. I can't remember when that began or if that is normal. Perhaps dust has built up inside and shorts something out?.....Help!
  • Anonymous Dec 20, 2008
    Same problem, mine goes into 'overload' after a just a few minutes and sometimes it may take a couple hours.
  • ssssss47 Dec 28, 2008
    same problem with mine as the rest of the posters
  • jbutler127 Jan 16, 2009
    The fan is not working and it goes into and overload mode and shuts down
  • calrojo9 Mar 14, 2009
    turn receiver on, it "pops" (loud noise) then turns off, please help
  • Anonymous Apr 25, 2009
    whenever i try to bump some music when i even get maybe like one forth of the way up the volume it stops playing the music and then shows a overload and then it turns off
    Genius:
  • 1,550 Answers
Maybe the audio amplifier IC are in short circuit you need to replace him.
Posted on Aug 18, 2008
We have a pioneer vsx-515-s/-k receiver with accusound om-650 subwoofer and accusound om-650 speakers but the receiver keeps going to overload after approx. 5 minutes of play , are they compaitable? or is the cause something else
Posted on Dec 11, 2008
When I turn on my receiver the "overload comes on ant it cuts off!
You were lucky the overload protection circuit kicked in, congradulation on finding it.
Mar 14, 2012 | Optimus STAV-3770 Receiver
Have recently had an "overload" displayed. Have
HI:
Usually receivers go into overload due to a bad speaker make sure you disconnect the speakers also to make sure its overloading from a bad speaker. If the unit still shows overload even with all speakers disconnected, then your main amplifier output has a short usually a shorted output transistor is the cause. Unplug the speakers one at a time to and turn the unit on after disconnecting one of the speakers , to determine which speaker is at fault.
Jan 23, 2011 | Panasonic SA-HE200 Receiver
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Receiver Overload error message
Disconnect all speaker wires at the receiver, then turn it on and up. If it stays on, check your speaker wires one by one, then check your speakers one by one. If it still cuts out with nothing attatched, it needs serviced or replaced.
Aug 30, 2009 | RCA RT2660R Receiver
Vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Apr 20, 2009 | Pioneer VSX-517
Overload & shotsoff
i cannot get sound as my ac receiver says overload what can i do
Apr 18, 2009 | Panasonic SA-HE200 Receiver
System is saying overload more frequently
Blow all the dust out of the unit with compressed air to prevent over heating (overload)
Aug 20, 2008 | Panasonic SA-HE200 Receiver
Receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
May 23, 2008 | Technics SA-DX930 Receiver
Overloading
What speakers are you using? Are they seperate from the TV set? How is the audio attached to the TV set. What inputs I mean are you using for the speakers and the sound for the TV set?
Dec 08, 2006 | Pioneer VSX-516-K
1,488 people viewed this question
 Grubhead
Grubhead
