Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia Same exact issue. We sent the first one back and 3 days after we recieved the replacement tv the same issue occured. Black out. If this is a power issue the Olevia keeps saying it is (I don't have enough power for the TV) then why doesn't anything else that's plugged into the power strip eg: cable box etc) shut off? I think I am getting refurbed TVs. Olevia will not refund of course the box store where I bought will not refund. I even opted to upgrade but Olevia said they do not do Upgrades either. Should I just spend the money on getting a new circuit board installed? I have to believe that it's the pixels dying and not a power issue. If anyone has any answers or good solutions I would be most beholden. Thanks Diane
  • Anonymous Aug 21, 2008
    OLIVEA 26, the scrren go blue...no video but audio works....how can I do to repair..Tk
  • qubbie Sep 03, 2008
    Everyone I think I have a solution to this issue.
    The "Pixel" circuit board seems to be the problem with this TV.
    They fry out and then in time will burn out.
    An easy "Fix" for Olevia but they refuse to admit there is a problem.
    I now have a fan on the TV when ever on and this seems to "Cool" the TV down hopefully this will be a fix..
    For those wall adhered TVS I wish you luck.
    The TV over heats and that is a call for a recall but like I said Olevia refuses to admit there is something wrong with this TV.
    Anyone know how to get a recall?
    Qubbie
I have a 47 a 32 and a 37 inch olevia tv. Just bought the 37 because i havent had any probs with the others. Well recently i moved my 47 inch and had it plugged into an outlet that had a one of those one into three strips plugged into the outlet and my tv kept shutting off. So i plugged it into another outlet and it worked fine so do try another outlet.
Posted on Sep 11, 2008
My TV randomly gets a blue screen with a no signal message. Exactly like the TV was turned on without my Dish Network box turned on. I thought the Dish box was going out so I replaced it. It still did the...
That can certainly be a frustrating issue!! Because you have already replaced the box, and you are getting the same thing, it is not a receiver issue. If you are able to temporarily get the TV to stay ona fter you turn it off and then back on, it could be a TV issue.
If your receiver and TV are plugged into a surge protector, try plugging them directly to the wall. Another cause of this issue could be your grounding for the DISH Network system, meaning that a tech may need to come out and inspect that. Feel free to send me an email if you continue to have issues!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 24, 2011 | Olevia 237T 37 in. LCD TV
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
I have an 18 month old acer AT3220B TV - it has always had a rather loud humming noise in the background and also the volume adjusts itself?! Now I have a vertical black line down the RHS of the...
The TV reciever is capable of recieving an interference especially if your mobile cellphone is near the TV otherwise the black line which is shown on your screen is not normal,you have to sent your unit the service center.....
Jun 14, 2008 | Televison & Video
My lt37hvs turns off by it self
I have the exact same issue. Some days I can play halo 3 online for ~8 hours and have no problems, but other days it just powers off and I have to leave it unconnected from the outlet for 3+ hours.
For those with the same problem looking for a better fix, do not leave the TV on to just idle on a pause screen or something of that nature. Try to get the HDTV an outlet with nothing else connected to it. Finally, putting a big *** floor fan cooling it down does seem to help. The TV is great considering the price and quality of the picture, but the issue makes it absolutely worthless in my mind. What's the point when you can't use it when you want to? Ugh, despite the great price of $600 for a 26" 1080i HDTV, I'm going to go with a Japanese HDTV next go around.
Apr 28, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Apr 13, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia 747 won't come on
I had the same problem with a 437. It just shut off one day and I could never turn it back on again. I called Syntax Brillian and they told me the mother board was probably shot. They sent me a new TV and took the damaged one back.
Feb 26, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia customer service
OLEVIA tV is a F#$King JOKE!!!!!.....I bought my tv in Jan and it went out 3 months after that, let me put it to you like this its Oct and i havent got my tv back to this day.
Got a case number and a tracking number that didnt make any sense. The shipping company they used didnt get paid so its been in there storage for 3 months. In some way if you have been waiting for your tv because of the shipping...Olevia is responsible for trans issue and pulling off on the shipping company.
OVERALL
DONT BUY A OLEVIA TV..... YOUR BETTER OFF WITH A LG!!!
Sep 28, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
219 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
