Question about Philips 42PF9630A 42 in. Plasma Television
Plasma Philips (42PF9630A) Top Half Has Artifacts
The top half of my plasma tv has developed artifacts... like those seen on a computer when the video card goes bad. What can this be and will the parts be expensive?? Thanks in advance.
  • GuzWorks Aug 19, 2008
    Lawrence1974 thanks for the reply. The Y upper board handles the upper screen buffer so that makes perfect sense. What about the signal board, why would I need to replace it? At any rate, thanks again for the help!
  • airbird Aug 20, 2008
    Hello and let me just say that it is wonderful that you take the time to try and answer these questions! I am experiencing the exact same type of problem. I have the same set and it has 2200 hours on it and I had the ssb board replaced in April 2008. At the time it would lose all channels and had to have the software re-installed each time to get the channels back. As soon as the set was turned off it would lose everything once again. After the ssb board was replaced it worked slick for a few months. Then this. odd lines every where. So my question is this- how do I determine the name and numbers of the small signal board or the Y upper board? I have a service manual but it doesn't mention anything about these 2 items. At this point I don't have the money for another EXPENSIVE service call. Could I order these items from Phillips and replace them myself? What would they be called in the service manual? Are they easily accessible? Thanks pal!
    By the way my model numer is 42PF7320A/37 slightly different than his model.
  • 36 Answers
If the lines affect the On Screen Display (tv menu) then the possibilty is that the Y upper Buffer is stressed and ther is not a problem with your SSB. Just remember that any of the Y boards and can stress the other ones out and cause probelms like the one you have, but I would be safe to say that replacing the Y upper buffer would solve your issue
Posted on Aug 20, 2008
  • 138 Answers
There is nothing you can do in the menu but a tech would need to be contacted. Bring up the menu and if the problem is not there replace the small signalbaord. If it is replace the Y upper board.
Posted on Aug 19, 2008
  • Anonymous Aug 19, 2008
    The SSB is the video processor If the problem is not in the SSB the SSB is good. Another way to determine if the SSB is bad is this and be very carefull when you do it. Take the SSB out the set and place a jumper on J8003 to short it.The place a jumper on J8004 to short it. They are located on the left hand side of the PSU.The place a jumper on CN2072 of the logic board. That is loacated under the SSB. Take the SSB out the set completely. Plug the set in and you will get a text patten. If the issue in the upper right hand corned is gone replace the SSB because we took that out of the set and the problem is gone. But if is is still there then replace the Ymain.I habe the part number for both.
    For the Y main I will need the LJ92 number off the logic board for that part number. And for the SSB there will be 3 numbers by that one.Get me the number with the (S) next to it.
SOURCE:
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
What might the problem be on a zenith tv
video control board remove back panel and look for bad capacitors
Mar 25, 2015 | LG Z42PJ240 42 in. Zenith Plasma TV
Ping/Green Bars on TV Display
I would first check and replace the cables to make sure you have clean signal. If that all checks out then I would consider putting in an amplifier in line to boost your signal. What is the distance you have on the cables all combined? Another thing to check in troubleshooting is to remove everything (cables) except the unit you are experiencing trouble with. If after all of this I would say your connection to your component itself is suspect.
Jan 27, 2014 | Denon AVR-4308CI Receiver
My 5 years old Plasma TV found half of the screen picture view not very clear.. The half colour seen blur..
Your Buffer boards or the YSUS main are bad. THe YBU-Y Buffer upper controls the top half of display, the YBL-Y Buffer lower controls the bottom half and the YSUS Main controls both those boards. They are located to the Far Left on and opened Set.
Jun 21, 2010 | Philips 42PF9966 42 in. HD-Ready Plasma...
I have a 4 yr old LG 50PX1D plasma tv and it works fine for about 20-30 min then the screen goes black. If you turn it off for an extended period, then back on, you can watch for another 20-30 min. Any...
Its either the XYZ circuits, power supply, or bad ESR conditions starting to develop. Have your local shop repair it for you....
The set is 4 years old, and usually problems in Plasma tv's develop before then......
Nov 17, 2009 | LG 50PX1D 50 in. Plasma Television
1/2 the screen goes black
vera partner what you have is a problem of poor voltage or damaged card card check your x that is the bottom of the plasma must consist of at least four cards
Aug 21, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Artifacts on monitor
two possibilities
either drivers files gone bad or
the card gone bad.
try the card on other computer
Nov 17, 2008 | Computers & Internet
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
201 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
