Question about Philips Audio Players & Recorders
I have a philips streamium WACS7000/05. I am unable to play CD's as everytime i put it in, it just ejects it back out again as if it cannot read it. I have tried several CD's all with the same issue.
  • Anonymous Jan 06, 2009
    i have the same problem and cannot get any help from philips
I had the same problem during the warranty period of my WACS. The result was that the laser reading the CDs was faulty and it was replaced. Since the laser was replaced it has been working fine
Posted on Jun 18, 2009
Philips dcm 230/37 cd player is playing c d shpws reading always. how to correct it
The drive may be failing; it is unable to read the CD and tries over and over again.
Jan 26, 2014 | Audio Players & Recorders
Philips Streamium WACS7500 STAYS ON CAN NOT USE
It is difficult to determine how much to repair because the computer needs a detailed check/test. Your computer repair shop can give you a quote.
Oct 08, 2012 | Computers & Internet
Wacs7500 streamium cannot read discs, just says 'no disc' or cannot read disc. have tried a cd lens cleaner with no success
remove the cover and gently clean the lens with a q-tip dipped in rubbing alcohol, then blow the lens dry. if all else fails, replace the optical pickup assembly (lens and spindle motor) or the whole player.
Jan 28, 2010 | Philips Audio Players & Recorders
Cd wont eject or play in a 6disck stock cd player
had the same problem with my cd player...just disconected the battery for 5 mins and put it back on the cd player ejected all the cds and plays them again.no cd error
Oct 13, 2009 | 2005 Lincoln Aviator
My philips streamium will not load cds
hey this happened to mine. I contacted phillips and as it was still under warranty and they collected it, fixed it and returned it within a week. do that and see how you get on
Oct 13, 2009 | Philips Streamium SL400i
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Not reading any cd format
Hi i have just been able to sort this problem, if your system says "NO CD" after it is inserted then the CD is not sitting right inside, solution for this is, join the philips club (free) and update the firmware and update the Gracenote software
1, insert the cd so it is in then turn it off and unplug then take another cd insert it in slowly to push the other one down a bit until it stops (may only move a couple of millimetres, you are only using the cd as it fits the slot so don’t try and insert it!!) plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
OR
2, insert the cd so it is in then turn it off and unplug then you can open the product and physically push the cd down (be careful when you take the lid off as the cd will not be fully slotted down and there are a couple of cables that can pop out but they are easy to put back and obvious) Put the lid back on and plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
any probs just mail back and ill help as much as i can
Oct 21, 2008 | Philips WACS700 Shelf System
LineOut
Yep. Take it to the nearest Sony Repair facility, usually when they say that there in an internal problem with the audio in from the laser to the audio ic
Don
Jan 02, 2008 | Sony CDX-R3000 CD Player
Cd is stuck
put the same disk in , play it for a while then eject it properly.
Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
433 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
