Question about Polti Vacuums
The yellow button on my Polti Vaporetto VT leader will not come on.
  • 1 more comment
  • webjewel Aug 18, 2008
    Yes the main connection is fine as the green light is coming on ok but the yellow light is the one that heats up the water and generates the steam.
    The yellow button on my Polti vaporetto steam cleaner is not coming on. The green button comes on so the main connection is fine.
  • webjewel Aug 21, 2008
    A friend managed to get inside the steam cleaner and one of the connections to the button was just rusty so cleaned off the rust and now the Polti works :) and I was nearly going to chuck it out and buy a new one !!! ...
  • 6,487 Answers
This problem needs some prat replacement so I suggest you to take it to a repair center near you and let them diagnose and repalce the parts that should be change..
Good luck.......
Posted on Aug 18, 2008
    Master:
  • 623 Answers
If that's the case then you should replace your heater...
    Master:
  • 382 Answers
Hello webjewel,
Please check whether the power supply to the vacuum is perfect if it is then the switch is faulty try to replace it or else there is fault in the power cord or inner connection..Thank you..
Please post on how things turned or for further assistance..
Regards!!..
  • Natesan Sabesan
    Natesan Sabesan Aug 21, 2008
    Gr8..Cheers buddy!.. :)
    Master:
  • 848 Answers
Check whether the connection is proper .....
Lost instructions for vaporetto polti 2400
Download instruction manual for Vaporetto 2400
Good Luck
Rating the solution is highly appreciated
May 31, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti spare parts
i have a 950 and it does not heat up any more . the red light comes on but thats it
Feb 13, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
POLTI VAPORETTO PROBLEMS
Hi, It is the solenoid that is sticking, It there fore needs opening up, the solenoid valve stripping and cleaning, or replace at a cost of about £12 then putting back together. they don,t like being left and not used. It is possable if you keep clicking for it to start working again.
Dec 09, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Vacuums Logo
127 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
