Run capacitor Hello, my blower fan on the outside isn't working but, the indside blower fan is, so, if the run capacitor is bad will the blower fan on the inside still run? Thanks
  • 182 Answers
Yes....they use seperate capacitors.
Posted on Aug 18, 2008
AC unit wont work, inside coils are hissing but outside unit not turning on.
If thisnis a central air conditioner and there is hissing at the indoor coil then the compressor is running, it is possible that both fans are not running. The indoor motor may not run if the control board is bad, capacitor is bad or the motor itself is bad. The outdoor fan may have a bad capacitor or the motor itself is bad
Jul 23, 2012 | Heating & Cooling
I've got a Air condition unit model BV124 30-10L16, which is the part of Lennox furnace unit. The indoor fan stops working now. The outside fan works fine. I checked the capacitor, fine too. Cooling...
Hello, a blower motor will not run for one of theese three reasons 1) No power to motor 2) bad capacitor 3) the motor itself is bad. One test you could do is take the wire of the L1 terminal on the control board and use a jumper wire and connect it to the wire on the high speed motor tap , if this gets the unit running then the control board must be replaced if it does not work then the motor is shot......make suremwhen disconnevting wires the power is off.
Sep 04, 2011 | Heating & Cooling
The outside unit has power going to it but isn't
maybe it has tripped off on high pressure, as you have have said the fan is not turning so will cause high pressure. now assuming the problem is the fan is not running than check the condition of the condensator /capacitor for the fan motor. if the motors winding is still good replace the capacitor and try it ON.
Aug 23, 2011 | Goodman CKL62AR61 Air Conditioner
My husband got up this morning and the coils were frozen and the blower was not and still will not run, we checked both breakers (indoor and out) and replaced the capacitor outside a month ago and replaced...
Hello, since you replaced the capacitor it only leaves either a bad control board or bad blower motor. If there is 120 volts to the motor then the motor is shot, however is there is no voltage to the motor then the control board must be replaced.
Jul 26, 2011 | Intertherm Heating & Cooling
The unit outside has the fan running, inside is not running at all
Hello, usually if the blower motor is not working it is either a 1) faulty capacitor 2) Bad motor 3) Malfunctioning control board If you try to spin the blower wheel by hand and it starts up then the capacitor must be replaced. If it does not start by pushing it by hand then it's either the motor or board.
Jun 29, 2011 | GE Heating & Cooling
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
Fan Not Working
either bad condenser fan motor or fan capacitor
Apr 24, 2009 | Samsung AW0503B Air Conditioner
Fan
Hi wild 36.
I think the problem may be a bad run capacitor. If the outside unit is humming with no action, that may be it.
This could also cause the outside unit circuit breaker to trip.
Greg.
Aug 18, 2008 | Heating & Cooling
Heating & Cooling Logo
211 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
