Emachines T2958 overheating
My computer keeps overheating. when I start it back up the screen says it was shut down for a thermal problem. The fan starts when you first turn it on, then it doesnt run anymore
    Genius:
  • Computers & ... Master
  • 1,056 Answers
Even though it is reporting thermal shut down, it may not be what the problem really is.
I've gone through this with Dell GX260's (same error, same function after. Or you can turn it on 7 or 8 times, and it might finally work).
Look inside the computer at the motherboard.
And look for the capacitors (they look like little cans standing on end, about 3/8" to 1/2" tall, about 1/4" in diameter).
If the tops are slightly dome shape, or they have a brown sticky substance around or on them, the motherboard is shot.
The repair is to replace the motherboard.
Posted on Aug 18, 2008
  • 2,794 Answers
Go to emachines.com and see if there is a firmware update for your computer BIOS. Some thermostat errors are cause by a BIOS fault that can be corrected with a firmware upgrade.
My laptop powers on and right back off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 26, 2013 | E-Machines Computers & Internet
My emachine T5088 shuts down - overheating. The 2 fans are working What to do?
Open the case, Are the fans, vents, heatsinks clean, free of dust? A little housekeeping may be needed. Improve air flow somehow. Also replace the Thermal Paste on the CPU. Try this little freeware program, SPEEDFAN at : http://www.filehippo.com/download_speedfan/
Boost the fans to 100%.
Feb 14, 2013 | E-Machines eMachines Desktop PC
Emachines t5234
Nov 27, 2012 | E-Machines eMachines Desktop PC
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
My computer E machine T3612 shut down due to thermal. Then only 2-3 beeps & never start. I checked Processor fan not working. How to result problems. thanks.
SAFE MODE
At start up press F8 go2 SAFE MODE thn type  at run chkdsk,chkdsk/f/r & thn restart pc
Else  Repair XP
Else clean ram BY RUBBER
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
Feb 26, 2011 | E-Machines (T2958) PC Desktop
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
Computer keeps shutting down. It will start up and sometimes work for a while then shut down unpromted. Or if I start it, the computer will just keep shutting down and restarting for no reason. I can get...
That sounds like either a graphics problem or more likely a memory problem. Try taking out a couple sticks of RAM or leave just one in and try that.
Nov 09, 2009 | Computers & Internet
Do the fan's spin when you power the PC on? All of the fans should spin up for at least a second upon initial boot. The CPU fan and video fan (if you have an external card) will spin the entire time the PC is on and vary in speed depending on temperature.
Try booting the PC with the side of the case off and note and fans that aren't spinning. The temperature to shut off the CPU is really high. If the temperature is getting hot enough to do this, you should notice a failure in a fan right away.
Mar 09, 2009 | Computers & Internet
Keeps shutting down 5150inspiron
thermal shutdown.... it's overheating and you need to make sure the fan is working and clean out the dust and dirt
Robert
Jan 19, 2009 | Dell Inspiron 5150 Notebook
Emachines T2958 overheating and shutting down
Your computer is automatically shutting down to prevent damage to the CPU because it is getting too hot. This can be caused due to a malfunction fan, heatsink, or dirt inside the CPU.
Remove the side cover of the CPU. Using a can of air (which can be purchased at most electronics departments), blow out any dust inside the case, paying specific attention to the fan and the heatsink mounting the CPU. Also blow out all vents and anywhere else you see dust. Do not shake the can of air and keep it as level as possible. If you do not have a can of air available, an air compressor will work. Alternatively, you may vacuum the dust up with the hose of a vacuum cleaner but do not use any attachment with brushes on it.
If the inside is relatively dust free, check to make sure all the fans are functioning properly. If the one on the CPU is not, then that fan will have to be replaced.
And one more thing, please give this solution a fixya rating. Thanks! :c)
Dec 27, 2008 | HP (158800-001) for Compaq Presario 1246,...
Computers & Internet Logo
287 people viewed this question
David Payne
David Payne
