Mouse will not work and i have tried resetting it many times
  • 177 Answers
Is your mouse USB connected.?If it is try using another one with a standard connector.
Posted on Aug 18, 2008
I changed the battery on my mouse and although the light comes on the mouse it will not move the cursor. Any suggestions?
You need to try restarting your computer and make sure that your receiver is plugged into your computer. I have this issue from time to time and this solves it.
Jan 23, 2011 | Logitech Cordless Mouse
Mouse does not work I have installed new batteris
Try hitting the SYNC button on the bottom of the mouse at the same time as hitting the SYNC button on the USB receiver (assuming this is a USB wireless mouse). Also try removing the USB receiver and plugging it back in.
Jul 07, 2009 | Logitech 9311570403 Mouse
Mouse doesn't work
LOOK FOR A BUTTON TO RESET THE MOUSE AND THE USB CONNECT SHOULD ALSO HAVE A RESET SWITCH ON THE USB CONNECT YOU NEED TO PUSH BOTH AT THE SAME IME SO THE CAN GET INSINK OR THE CHANNEL TO SET. SOME TIMES THE MOUSE HAS TO BE TAKEN APART AND CLEANED JUST LIKE THE OLD MOUSE BALL ONE, AND RESET THE MOUSE SETTING IN CONTROL PANAL, UPDATE DRIVE MAY ALSO HELP IF THERE IS ANY NEW FIXS
ROD
PS SOME TIMES THE LEAD TO THE BATTARY CONNECTION NEED THE THE SPRING PULLED OUT A LITTLE OR THE OTHER END WITH METAL TAB ON IT NEEDS PULLED OUT BECAUSE THE PLAY IN THE BATTERY COMPARTMENT IS LOOSE AND THE CONNECTION IS INTERMITTING A VOLTAGE CHANGE AND CAUSES THE MOUSE TO LOOSE ITS SIGNAL TO THE TRANSMITTER OR SET FREQANCES.
ROD
Feb 09, 2009 | HP Wireless Optical Mouse
Button works intermittently on Kensington Wireless Mouse P/N 6439
battarys maybe running low on juice or the ball may have oil on ball, look for reset switch on buttom of mouse press on it,
if info ray type clean the light area, reset the mouse and the usb plug in usb mouse adapter, it may be colored ot not, should be the same color as the mouse one is reset both at the same time.
rod
Feb 06, 2009 | Kensington PilotBoard 64385
Mouse not working
I opened the mouse and took the batteries out and double checked their placement and even though they were in correctly the first time, the mouse started working the second time.
Thanks for your response.
Nov 11, 2008 | Logitech LX5 Cordless Optical Mouse
My sister recently went to get her laptop fix but before the mouse was working find but after she got it back it doesnt work at all
Try resetting the mouse. On the base of the mouse, there is a red reset button. Press that, while simultaneously pressing the black reset button on the base of the charger. The laser light should becomes steady after a moment, indicating that the mouse is in sync with the laptop. If the laser is blinking, however, then the mouse is attempting to become synced. You may have to press the reset button multiple times. Hope this helps.
Jul 03, 2008 | Targus PAWM001U Mouse
Wireless mouse problem
Try this:
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jun 25, 2008 | Dynex Wireless Optical Mouse DX-WOM100
Belkin Wireless Mouse
Today I tried pressing the reset button on the bottom of the mouse, and at the same time pressed the button on the top of the remote reciever. I'd pressed both in the past, but never at the same time. This seems to have fixed this problem. I hope it's a solution for others also.
Dec 21, 2007 | Belkin Wireless Keyboard/Optical Mouse...
Logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
Dec 20, 2007 | Logitech Cordless Desktop MX3200 Laser...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
