Ac adapter can I use any power adapter that has the same voltage and wattage and tip configuration to power my toshiba laptop?
My first thought is "yes" as long as it says Toshiba on it, but if you have one that fits, check for the same wattage, and amps. The whole thing could go up in smoke even if the adapter has the right voltage - if the amps supplied by the adapter are too high.
Thanks,
Mark
Posted on Aug 18, 2008
  • Micklaptop Aug 18, 2008
    Thanks,
    Mark
Toshiba 1905-s301 wont run on just ac power
Check your AC Adapter for voltage output using a multi-meter. If voltage is lower than stated replace Adapter. When replacing adapter verify Amperage is same before purchase.
Dec 18, 2013 | Toshiba Satellite 1905-S301...
When ac adapter is plugged in, only AC led blinks green, (no batt, no ram, no HDD) and after pusshing the power button several times, power led blinks greeen for a split second, and the computer never...
Try using another ac adapter, sounds like the adapter is failing. You can either ask if one of your friends has the adapter with the same connector and voltage (check that the wattage of the adapter is sufficient) or if someone has a universal ac/dc adapter for the test. If the laptop starts normally wiht another adapter, then get a replacement adapter and you are good to go.
Oct 10, 2013 | Toshiba Satellite L455D-S5976 Notebook
AC power adapter wattage cannot be determined
The AC adapter needs to be replaced. You can buy one from Dell for about 100-200 dollars. If your laptop is still under warranty, the charger is often covered under the same warranty as the laptop and should be replaced under warranty if applicable. You may also buy a third-party charger off of ebay or amazon much cheaper, but this is not recommended. If you do consider a third party charger, make sure that it has the same wattage, voltage, everything! Good luck!
Mar 23, 2013 | Dell LATITUDE Computers & Internet
A665 Toshiba satellite when i switched on no dispaly after a while it's turn off the fan is noisy
Please remove the battery and ac power adapter. hold power on button for 1-2 minutes. Then try to power on laptop with ac power adapter without battery. check the display of laptop.
If not check the dc voltage of the ac adapter. is it the same voltage as written on the ac power adpater. if not same please try with another adapter.
If not remove the hard disk and ram. clean the fan,ram. Reinsert ram and power on with ac adapter. check the display.
Please check with external display if laptop is turned on but no display.
Jul 01, 2011 | Toshiba Satellite A665-S6086 Laptop
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Hanging
power from adapter no capable to supply and need more wattage or change adapter with higher amperage. but still you need to change new battery.
Apr 02, 2010 | Toshiba Satellite A205-S4617 Notebook
Green light on ac charger goes out when i plug it in to lap top
This indicates a short in the computer or power supply. The power supply senses the problem and shuts itself off. Does the laptop run at all? More info. is needed to correctly solve your problem. Send me a message and I will help you out. Phil
Dec 09, 2009 | Dell Inspiron 1501 Notebook
Power to Toshiba L25 s1196 laptop
make sure the output wattage and voltage of the universal matches the original, if not you can damage the PC. look on the actual inverters, they take AC wall voltage and Transform it to DC power, the specs will be listed. some universals have switches to adjust the voltage, etc.
Mar 30, 2009 | Toshiba Satellite L25-S119 Notebook
Keeps loosing battery/power
If it will not work on AC Adapter without battery in it, then you have a bad AC Adapter and the battery is fine. You don't have to get an expensive AC adapter from the original manufacturer. Just look on the bottom of the AC adapter and write down the Volts and Wattage. You can get another at a place like Lowe's or Home Depot. But you must make sure that the Voltage matches exactly, to much voltage and it will fry your computer, to little voltage and it will not run your computer.
Dec 23, 2008 | Toshiba Satellite 2455-S305 Notebook
AC/DC adapter
Make sure the voltage and amperage is the same and the tip fits.
I use I-GO universal from Radio shack
Apr 19, 2008 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
David Payne
David Payne
