Creative Gigaworks S750 Subwoofer fuse went out. Replaced it and power came back on but as soon as i take the system off from stanby. The Fuse blew again. Ive replaced over 5 fuses and using different sockets, all ended in the fuse blowing then removing standby.
  • jordanes Mar 18, 2009
    I ve got the same problem i change fuse, turn subwoofer on and then when turn on the control station after 3 seconds fuse burn and everything is off. Please help me with this.
SOURCE: amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Posted on Feb 08, 2007
  • 99 Answers
SOURCE: Gigaworks S750
If you check the Creative forums there is a thread there where a few people have started to fix problems like this permanently and they have helped quite a few people fix their problems. I would only suggest checking it out if you have any electronics experience (soldering, and basic troubleshooting minimum). Otherwise I would send it back but keep in mind that this is one of a few common problems with the S750's and you are likely to have other problems in the future unless you take measures to fix the problem that creative has not.
I would also like to point out that your problem would be a short on one of the amp boards after the power regulators, very likely one of the STA575 amplifier ICs. Those are not easy to find but it is possible to find replacements.
Posted on Dec 16, 2007
marsrover
  • 682 Answers
SOURCE: My JBL PD12 subwoofer stopped
check the cable between your sub and the receiver for short circuit and if the cable is ok you will have an problem in the printed board.
Posted on Jul 11, 2008
  • 3 Answers
SOURCE: AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Posted on Nov 13, 2008
  • 26 Answers
SOURCE: fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Posted on Mar 10, 2009
I have a Creative Gigaworks S700 i have checked both fuses still no power to control box
Stupid question: does the sound still work? it could be the LED just died after continual use (rare, since they last a long time, but not uncommon).
If not... it could be the controlling circuit board died. In which case, unless you have electronics repair experience, it would be probably more worthwhile to just replace the speakers, as pricey a model as it is.
Mar 23, 2012 | Creative Labs Gigaworks S750 Computer...
Subwoofer will not play with other speakers
Hello
It looks like you have posted this before. Unfortunately, I don't know what you have tried so I may be repeating some of your earlier troubleshooting.
The subwoofer needs its own power supply to function properly. if it isn't getting enough power, the sub will not work at all.
On the back of the unit, you should see a green LED when the power is turned on. Is this light on all of the time of does it fade / flicker? This would indicate the power supply is going bad and you need to replace it.
http://forums.creative.com/t5/Speaker-Systems/GigaWorks-S750-power-problems-green-LED-faded-and-flickering/td-p/547311;jsessionid=9B7C9D2D939336148A9036D7E7D18A12
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
I have a Creative Gigaworks S700 (subwoofer) with no power out. LED off. Fuse ok.
first fuse as standard is in the plug to the power adapter. The second fuse is located at the back of the box where the power lead goes into. It is covered so look closely you just need something flat to open it. I have the S750 and that is what im basing this on but if the s700 is the same then you will find this helpful. Sorry did not notice this before.
Hope this helps.
Dec 11, 2009 | Creative Labs Gigaworks S750 Computer...
Fuse blows after turning on control center
I have a similar problem on the Gigaworks S750 system. Upon opening, I have found that the IC driving the switch mode power supply becomes basically a short, and that the transformer becomes damaged as a result there of as well. Then you have about 22 Ohms connected to your mains (after the bridge rectifier) which causes the fuse to blow. Is there anyone that can assist with a circuit diagram for this system, or of contact details as to where I can find out what the specifications of the transformer is? Can not seem to find any technical assistance in South Africa
Jun 17, 2009 | Creative Labs Gigaworks S750 Computer...
All I need is the control pod for the Gigaworks S750
I had an extra one but I sold it. According to creative labs they do not sell any replacement parts for the speaker systems. The best suggestion that I can give is to check craigslist and ebay for the control pods.
Dec 13, 2008 | Creative Labs Gigaworks S750 Computer...
Audio control pod seems dead
You can see about getting a new control pod from ebay or craigslist but the problem is more likely inside the subwoofer. Below I have pasted a link to a forum thread about fixing the Gigaworks S750 systems. There is not much information there about control pod problems but at least the people on the thread will help as much as they can. If you are not familiar with electronics then some of the people on the forum thread can help if you are willing to ship the subwoofer box to them.
http://forums.creative.com/creativelabs/board/message?board.id=speakers&thread.id=8037&view=by_date_ascending&page=1
Nov 09, 2008 | Creative Labs Gigaworks S750 Computer...
Creative S750,all speakers distorted
Your problem sounds like it is the high voltage power supply not working. I would start by checking the IRF740 MOSFETs on the power supply board. Below I have pasted a link to a forum thread about fixing the Gigaworks S750 systems. There is a lot of information there about the problem you are experiencing as well as complete diagrams of the power supply and good pictures.
Oct 25, 2008 | Creative Labs Gigaworks S750 Computer...
Gigaworks s750
Same problem just went out after about 4 years.... weak lifespan for a 500 dollar system
Feb 12, 2008 | Creative Labs Gigaworks S750 Computer...
887 people viewed this question
 Grubhead
Grubhead
