Sony KP-57WS520 57 in. Rear Projection HDTV-Ready Television
Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready...
KP-57WS520 9 LED blinks
By NavAnd on Aug 18, 2008
I have a Sony WEGA rear projection TV, model: KP-57WS520
The standby light flashes 9 times, pauses, and flashes.
I opened up the TV to check the G board. Did find it and found
the Diodes D6116 and D6301. I noticed that there is a connector that
is connect to right, so to replace do I have to unsolder and then solder
the new board if I buy one. Where can I purchase a new G-board for this
model of TV.
Thanks for any assistance.
I really appreciate your help.
Same Problem
May 17, 2009
-   Yes i have the same 9 led blinks and it will not turn on. Is it me or this sound like a common problem for this unit? Can someone post more on this g-board issue? I notice that thier was a few comments about not having to replace the whole board ang getting the parts from MCM Electronics. Someone please list more about this...Thanks Perry J. from St Petersburg Fl.-   Guest
May 15, 2009
-   9 blinks - tv will not power up! What do I do?
-   swalter728
Nov 20, 2008
-   I have not tried anything yet but my tv model number KP-57WS520 blinks 9 times and will not turn on. -   dframpton
Oct 10, 2008
-   Same issue. LED blinks 9 times. TV will not power up. I called for service. They said the CRT needs replaced. Said could not be repaired at my house but that they needed to take it to their shop. I do not know the vendor Premeir TV Repair 419-462-5275, bit Geek Squad from Best Buy referred me. Anyhow, the kicker, they said repairs would run $685, plus tax. The TV new 4 years ago was $1500!-   TheBanker999
Best Solution
posted on Oct 18, 2008
Very Helpful)
mistersony
Rank: Guru  Sony Expert
Rating: 93%, 291 votes
Don't replace the entire G board! that is expensive! The diodes are available from MCM electronics and can be easily replaced.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Oct 19, 2009
Not Rated)
jm_transport
Rank: Apprentice
Rating: 0%, 0 votes
I got one from a friend that he gave to me.
Only problem is he tried to replace them, Because once i looked at the board the diode on the top (componet side) was replaces with a 1n4001, and the one on the bottom side was gone.... and the traces are loose rom the board, and the transistor that it runs across had black tent on the legs, so i guess he tried to put a 1n4001 there also, not positive just a good guess. I think ill have to buy a g board because i don't think that i can buy the resistor and transistor and then not get them mounted to the board. any thoughts?
Was this helpful?
Yes
No
Solution #3
posted on Jun 14, 2009
Not Rated)
flara
Rank: Apprentice
Rating: 0%, 0 votes
There is a problem whit this g board, one diode D6116 is a surface mount sometimes you can resolder these two but will work just temporarily it is recommended to install new ones, are u talking about the connector pluged to the antenna? this is usually hard to pluck from the G board you should try to disconect from the antenna instead, Don't break it cause these boards are discontinued from sony. Good luck.
Was this helpful?
Yes
No
Solution #4
posted on Apr 26, 2009
Not Rated)
vishddish
Rank: Apprentice
Rating: 0%, 0 votes
standby light blink 10 times on sony kp-57s520
Was this helpful?
Yes
No
Popular Solutions for Sony KP-57WS520 57 in. Rear
Questions and Unsolved Problems for Sony KP-57WS520 57 in. Rear
Do you recommend Sony KP-57WS520 57 in. Rear Projection HDTV-Ready Television?
Answer
Answer
my picture is inverted on my Sony KP57WS520 television. The picture tube appears to be fine
Answer
i have a sony kp57wv700 and is blinking seven times then picture shuts down
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
