Question about Sewing Machines
Bernette 65 Sewing machine
I'm thinking about purchasing the Bernette 65 sewing machine, but after reading some reviews on it, i'm thinking twice. Have you had many complaints or problems with this model. This is my first machine, and I'm wondering if it's a reliable starter. Any help would be greatly appreciated!
Michael
  • 202 Answers
As a Bernina tech I may be a bit biased on this but I can say this... If you decide on this machine be sure you get it from a dealership with an on-site technician. Any can be an Authorized dealer but not many have a Certified technician. Not to say that you will need one but if it does get an issue in can be taken care of promptly. Also Bernina dealerships are required to have a class for you on their machines. I have worked for a Bernina dealership for the past 5 years and have not had a Bernette come in for a repair. Of the reviews I've read the complaints are of the tension which seems most likely a user default such as not keeping it clean after use, using cheap thread, not understanding how to adjust it for different fabrics, the right type of needle, etc.
I like the 1 step buttonholer and the threader. I wish the lighting was better.
If your going to spend less than 200.00 on a new machine you could do much worse. If you decide to not do the Bernette consider the Janome line next. (with an on-site tech)
Good luck.
Posted on Aug 19, 2008
Does the bobbin case of a singer fit in the bernette 65?
No. You need to purchase a Bernette bobbin case for your machine. Check with your Bernina dealer.
Jul 18, 2017 | Singer Sewing Machines
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
How to insert bobbin in a bernette 680 sewing machine?
Try going to this link and download the manual for either the Bernette 410 or 715 and look at the directions for threading and inserting the bobbin:
Bernina may not have a manual for your particular model, but these models may be close enough that you can still use the directions for your machine.
Jul 07, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
How to install Bernette 65 walking foot?
Here is the link to the manual for the Bernette and it shows how to install and use the walking foot. Good luck with this! THe Bernina is a great machine.
http://www.manualslib.com/manual/389081/Bernina-Bernette-25.html?page=61
Apr 16, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
Why won't my Bernette 65 pick up the bobbin thread
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 14, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
My Bernette 65 sewing machine isn't pulling my main thread through. Bobbin tread is being pulled fine. What could the problem be?
Make sure you have a new needle in first and the correct way round, failing that the machine may need retiming
Sep 19, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
My Bernina Bernette 65 manual does not show how to oil it- do I need to?
If there is no oiling mentioned in the maintenance part of your manual then your machine probably has nylon gears and maybe an oiling wick - many of the new machines are built this way to reduce maintenance issues.
However, if you purchased it from a Bernina dealership, I would ask them that question. Your manual probably recommends you take it to an authorised dealer periodically for a service when they would lube the parts that need it.
My Janome local dealer told me to put a drop oil under the bobbin case in my 6500P every couple of months onto the wick or if it sounds a little noisy.
Apr 15, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
Sewing Machines Logo
906 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
