Question about Dell Dimension 4600 PC Desktop
Dell Flat Screen 19"
When my dell flat screen monitor is turned on the screen remains black but there is a floating box on the screen that states 1:Analogy self assessment. The box also has thick parallel panels with the colors red, white, or blue on a panel within the box.
Please advise what is going on.
Thank you.
eulabooker@knology.net
  • 197 Answers
It sound like you eather need a new video card or there is something wrong with your moniter.
thanks
hope this help you
Posted on Aug 22, 2008
  • Vannaleth Sisongdeth
    Vannaleth Sisongdeth Mar 21, 2012
    I have that same problem once turn out it was my vga port on my motherboard....your video card might be malfuntioning check it with another monitor and if thats not the issue then your monitors vga cable is bad
    Sergeant:
    Champion:
  • 317 Answers
The monitor is not detecting an input on the Analog in put, it could be a number of things, such as a bad VGA cable, faulty video card, or the monitors signal decoder, has decided to go on the fritz.
Dell Pc won't boot gets black screen with floating dialog box
Floating dialog box is the monitor's self test. Your monitor tests good. Your computer is the problem.
Mar 04, 2013 | Dell Dimension 3100 PC Desktop
I have a Dell 1905FP monitor and the screen went black and the Self Test box is floating around. Rebooting does not help. Please help. Rich
Try deconnect and reconnect the screen to the computer. You can also try to use a different cable or port on your computer to connect it. Also, in the "video preference" of your computer, be sure you activate this monitor.
Mar 01, 2011 | Dell E152FP 15" Flat Panel LCD Monitor
Dell 17inch flat screen monitor will not remain on, the screen go
If your Dell monitor still under into warranty, better to call Dell technical support and have them replace your monitor coz there is no way you can fix on it.
If the monitor is beyond with the warranty already, better to but a new one than taking it repair that will cost you much.
Thank you.
Oct 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Turn on the monitor
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Black box on screen
I was having the same problem. Try making sure Closed Caption is turned off. It is CC on the remote.
Oct 08, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Dell Dimension 4600 PC Desktop Logo
457 people viewed this question
Alun Cox
