Re: Am using colleagues camcorder and want to download to...
Install Pixe VRF Browser EX using the provided CD-Rom.You can import Video footage stored in a DVD recorder or DVD camcorder to Mac. Download this manual...->start Download ,go to page #131 .
Do you have iMovie? On mine, with any camcorder I've had, when I have iMovie running and plug the camcorder in it automatically changes to the Record mode. Click on the forward button and it will start the camcorder. Press the Record button when you get to the part you want to record. You can then edit the beginning or end of the section to use the portion(s) you want. The software controls the camcorder to go frontwards or backwards. Works very slick. Not sure what to suggest if you don't use iMovie.
I expect that Firewire 800 is backwards compatible with 400. You just need a cable with the appropriate connectors on each end. The Mac surely comes with the drivers already installed.
How it works with my mini-DV recorder (on a PC) is that when I fire up the video editing software, it sees the camera as a source and can control it from the computer to rewind and download. The book says use the mains power adapter to make sure the camera stays powered.
The computer is no longer detecting the camcorder for several reasons. It could be the ports on the computer, it could be the cable that you're using to connect the camcorder to the iMac, or it could be the camcorder itself.
Try connecting the camcorder into different USB or FireWire port of the iMac.
Try using different cable.
Try connecting the camcorder into different computer to test the device.
If all else fails, power cycle the camcorder by turning it off and remove the battery for about 10 minutes. Then turn it back on. Otherwise, contact the manufacturer for second opinion.
USB bad. If the footage is on hard drive rather than tape just browse the camera or import rather than capture. If difficulties seeing the hd maybe use a card reader known to work with mac. If it is on DV tape you need to connect to a dv / hdv out to fire wire, if this camera doesn't have one you will need to borrow some one's who does.
