Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic 47wx53 covergence issues
2 to 3 weeks ago my 4 year old rear proj panasonic TV had blue ghosts and then horitontel lines became waivy. After reading this website I diagnosed the problem as being the convergence. Now after this weekend the picture will not come on and I only hear the sound. Is it the convergence and the bulb? Or did we kill our TV because we were not prompt on fixing the convergence and contiued using it even though the picture was distorted?
  • 1 more comment
  • kpoulsen Sep 01, 2008
    convergence problem with panasonic PT-47WX42F
  • njones278 Oct 08, 2008
    Dear Slinterios, I replaced the IC and purchased them where you suggested. TV comes on for 1 scecond and then turns off. Are these the generic IC's? In other posts people suggest NOT to use the generic. What could be wrong with our TV?
    This did not work. We bought the IC's from servicemanuals and installed them according to all directions. TV comes on for 1 second with only sound then turns off. I was looking at other IC problems on this Site with the same tv but with answers from other technician and they say DO NOT BUY the generic IC's, ONLY buy the Panasonic ones. Are these the generic ones that we bought? And is that why it is not working after replacing the IC's?
  • Panasonic Master
  • 8,617 Answers
Is the power indicator flashing three times? If so the Ics have shorted shutting the set down. You will need two STK392-110 convergence ICs. You can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Posted on Sep 01, 2008
SOURCE:
Have a Panasonic PT-47WX53 47. It's probably as old as when it came out. I've messed around with the convergence before but it was never un-fixable. Then a couple a days ago I came into the ro
yes and also possibly the low ohm resistors. You can get the PT53WX53 convergence kit which fits your model from www.tvrepairworld.com which has the 2 ICs and associated resistors plus the CD with repair instructions.
Jun 09, 2012 | Panasonic PT-47WX53 47" Rear Projection...
I have panasonic rear projection tv. There is
The PT53WX53 convergence repair kit available at www.tvrepairworld.com should repair that issue. The repair kit contains the parts and the CD with instructions.
Oct 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic 53" tv
Blue background lines with colors otherwise OK may be a loose or dirty blur drive potentiometer on small circuit board behind front grille and beneath front imerboard cover. These are hot-glued in place from factory but may be the cause f the problem. They're VERY sensitive.
If you have bowed blue lines instead of properly aligned colors, you probably have a blown convergence amplifier IC. These boards are no longer available so yours will have to be repaired. Some shops repair them but many send them out for 6-10 weeks. Fairly expensive too considering the amplifier chips are about $35 each (x2).
Jun 01, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Blue/Green on edges of Panasonic HDTV CT-36HX42
rear projection TV is light emitted and therefore can be fixed by a lamp replacement. I know the replacement's can in some cases be more expensive than a new model. Search the web for lamp replacement based on your TV model to get an idea.
Nov 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem, blue ghosts
you need to replace both convergence ICs they are both STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
Sep 01, 2008 | Panasonic PT-47WX53 47" Rear Projection...
My panasonic HDTV bbl 1080i was purchased about 6 or 7 years ago. The image shows two or three other images from the original image which are florence green and pink. So basically I see a triple image of...
I have a Panasonic PT-47WX53 rear projection TV and the picture was pretty dark for the last year but for game it was OK but know the blue is out of sequence, do I need to change the lamps?
And where to find them?
Jul 26, 2008 | Panasonic Televison & Video
PT-47WX53 blue convergence PROBLEM
Sounds like you have a blue foldover in the convergence. Since tv has been worked on it could be bad ic, maybe not original, generic. I would say if you can open set and look in, look for the blue it should be marked. look for a loose connection. If you can have someone to gently tap around that blue amp and see if it moves are go away, it might be a simple loose connection and needs soldering. If not then my have to change ic again. Becareful cause set would need to be on to really check. Hope this helps.
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
130 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
