Question about Compaq Presario Notebook
Laptop not charging (Presairro C500)
My brother's laptop is not charging. Vista says it is charging, but the battery meter isn't going up. It seems that plugging it in only discharges the battery faster. What is the problem? We use his other laptop to chatge this one.
  • 2 more comments
  • ae_7fam Aug 18, 2008
    Thanks. I'll get to it when I can
    Just a couple questions- how much (if any price), and what exactly does it do?
  • ae_7fam Aug 19, 2008
    TFT., but this is obviously a hardware. When the battery's removed, the power light blinks like crazy and something buzzes.
  • ae_7fam Mar 07, 2009
    OK... Sorryif I seemed rude. However, I know it is a HW problem. I have connected 4 different power supplies to it, 2 HP original, and they don't work with it. They are not faulty because they work perfectly well on another one.
  • ae_7fam May 07, 2009
    Suspecting fauty component... Trying to save up for MB off eBay.
Need to order for my Lap top Recovery Disk Need Phone No
my EM- IS Frances Lovegren lovetko8@fairpoint
Posted on Aug 18, 2008
Battery gets to 8% or so, I plug it in, it says it's charging but warning keeps flashing, screen dims off and on and then it shuts off. Charges fine when it's off. Seemed to work fine before.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 02, 2013 | Samsung N310-13GB Netbook
Gateway vista amd
Oct 15, 2012 | Computers & Internet
No battery detected
LOL, good ole Vista. I would never discharge my battery once I got it charged. I know the instructions say that, but I just never do it. Sounds like your battery is defective. Send it back.
Apr 08, 2012 | Computers & Internet
Powercord replacement
please explain further.. do you mean your laptops power adapter cord?
thanks for using fixya
Nov 10, 2011 | IBM ThinkPad 380ED
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
My acer aspire battery discharges and does not hold its charge when not connected to the mains
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all. Then the battery needs to be replaced.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jan 03, 2010 | Acer Aspire 5315 Notebook
My Compaq nc6220 only starts up when the ac adaptor is plugged in. I think the battery needs to be replaced. does this sound right ?
To check if the battery is charging go to Control Panel - Power Options - Power meter. If it shows unknown or zero charge then the battery is faulty or worn out. Rechargeable batteries have only a finite amount of charge and discharge cycles and over a couple of years use they lose their full amp hour charge capacity.
Jun 10, 2009 | HP Compaq nc6220 Notebook
Battery wont work
The battery is dead and it won't charge or hold its charge (all rechargeable batteries have a finite number of charge and discharge cycles). You need to buy a new battery, or just use the laptop connected to the mains supply.
Oct 29, 2008 | HP Compaq Evo Notebook N600c
Compaq Presario Notebook Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
