I have installed Printmaster version 18 to my computer, running windows vista. I cannot, however print from the program
  • 177 Answers
Make sure your printer is not offline.
Posted on Aug 18, 2008
Having compatability problems installing
Hi, PrintMaster is known for having versions that are not compatible with certain Windows Operating Systems, 18 is known to not work with Vista, yet works with 7 and XP quite well. The best solution would be either to upgrade to Windows 7 or get another version. Good luck!
Jan 10, 2016 | Broderbund PrintMaster Gold Version 18
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
Windows 7 Professional + compatibility with Broderbund Print Master Platinum Version 18
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Broderbund Print Master Platinum Version 18, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Nov 20, 2010 | Broderbund PrintMaster Platinum Version 18
I installed window 7 into my laptop. My printmaster platinum 18 is now not working properly. What can I do to resolve this issue
Right click on the program shortcut click on properties from the menu and click on the compatibility tab , check "Run this program in compatibility mode of windows xx" and select the version of windows in which the program used to run. Apply the settings and open the program again. If the program still doesnt work try to reinstall or get an updated version for windows 7 maybe Print Master 2010.
Sep 12, 2010 | Broderbund PrintMaster Platinum Version 18
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
All the best with your install.
Kind regards
Jul 20, 2010 | Broderbund PrintMaster Platinum Version 18
Why don't they make a CreataCard ''Gold'' that works using VISTA?? I missing this great program
Create a Card is a discontinued product.
Encore has new PrintMaster® Gold Version 18 ($19.99) and PrintMaster® Platinum Version 18 ($39.99) programs, both with Vista support :
http://www.encoreusa.com/products.aspx?SearchTerm=create+a+card
Aug 16, 2009 | Computers & Internet
My printmaster Platinum 10 version will not install on Vista.
downgrade too XP 10 is not compatible with Vista
May 02, 2009 | Computers & Internet
I have the Printmaster Platinum Version17 , I cannot save to pdf files?
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
Apr 01, 2009 | Broderbund PrintMaster Platinum Version 18
I am fairly new to PCs. I recently purchased a Toshiba 205 and have Vista SP1.  I purchase Print Shop Delux 22 and started the installation process before I read the statement about don't start...
Hello, Encore Software has released a patch to make Print Shop Deluxe 22 compatible on Windows Vista.
Here is what they say here:
http://support.encoreusa.com/kb.asp?id=571
Problem I am looking for the Vista compatibility patch. Solution This Windows® Vista update will detect and repair The Print Shop® 22 and PrintMaster® 17 applications already installed on your computer. After applying this update The Print Shop® 22 and PrintMaster® 17 will operate normally on computers running Windows® Vista.
Update Instructions
1. Click the link located at the bottom of this page.
Note: For Microsoft® Internet Explorer® the File download dialog may appear. Select Save this program to disk and click OK.
2. Choose a location (e.g., the Desktop) and click Save. The download process will begin.
3. When the download is complete, close the Download window.
4. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update.
5. Follow the onscreen instructions to complete the installation.
Note: Depending on system or user account settings, you may encounter several interruptions during the installation process. If so, please click Continue or Allow in order to proceed.
6. Launch and use The PrintShop® 22 or PrintMaster® 17.
Click here to download Broderbund_Print_Update.exe (26.7 MB)
Aug 21, 2008 | Computers & Internet
Printmaster and Windows Vista
been running printmaster platinum 8.0 for many years on several different computers . have had it installed and running on my HPPavilion slimline for two years now . problem is that i cant get it too print anything new that i create it will print out older stuff that i have created but nothing new . have checked drivers on print they are all up to snuff , and have uninstalled and reinstalled both the printer and the printmaster program but still cant get it too print anything new that i create . it does print everything else in the PM program. and otherwheres on my computer
Feb 09, 2008 | Broderbund PrintMaster Platinum 16
Computers & Internet Logo
David Payne
David Payne
