Question about Toshiba 57HDX82 57" Rear Projection HDTV
Toshiba convergence Thanks for replying to my FixYa post. I've added my results to that post, but I wanted to let you know that I have a picture showing the set's convergence problem, if that is useful. Send an email to mhomiller (at) hotmail (dot) com if you want me to send the picture. thanks, Matt
  • mhomiller Aug 19, 2008
    Thanks for your help - I'll probably consider this as a last resort. I've read that others have replaced with -180s without problems. Plus, the fact that the set is unchanged makes me wonder if my -110s were bad in the first place (and no fuses were blown and resistors are ok).
    thanks again!
  • mhomiller Aug 22, 2008
    I found the datasheets here:
    http://www.electronica-usa.com/Merchant2...
    The -110 and -180 are identical. I even compared the typical application circuit and test circuit.
    I have a scope now. I'm looking at the schematics to see what points might be interesting to probe...
  • 2,334 Answers
I was looking through the voltage readings and they are almost identical as the schematic diagram.
The STK392-180 that you used instead the OEM ones, might have a different horizontal frequency affecting the convergence alignment and there should more more changes made to the circuit to accommodate the higher wattage STK IC.
I would suggest to use the STK392-110 as design by the manufacturers and see if that works.
Let me know if you need further assistance.
Posted on Aug 18, 2008
I've format my Windows xp and I lost my sound drivers. AD 1885 soundmax.???
First reply your PC specification brand name and model# of your PC (if desktop motherboard brand name and model #, if laptop brand and model #).
Please see this sample image.
Just let me know if you already check-up brand name and model #.'
Thanks for using Fixya
Aug 20, 2011 | Computers & Internet
The picture looks like it is in 3D without the glasses. the picture is fuzzy and off color
It sounds like you are describing a set with bad convergence. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 06, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
My 50" Toshiba has a color problem!!!
Ur convergence is dead.Must replaced the 2 Convergence ICS and all it resistors.By replacing these 2 convergence ICS well solved these problems colors misalign, 3D double pictures,blurry pictures.The shop will cost U $300 for parts and labors.
Jan 23, 2010 | Toshiba 50H81 50" Rear Projection...
Picture bows and shadow
Hello, asnowman here.
I had to reply to this post, as the other would not let me.
Your question:
Comment posted on Oct 26, 2009 Thank you for your help, do you know what board this is on? signal, main, or power? Your televsion is the 73411, and I think that your convergence IC's are on the center board, (called the power board, even though it doesn't have the flyback on it), if they are not they are on the signal board. You can't miss them they are attached to a very large aluminum heat sink and the IC's are very large as well. I hope that this answers your questions. If you need further assistance please comment to this post and I will try to help you further.
asnowman
Oct 26, 2009 | Mitsubishi WS-73411 73" Rear Projection...
Where can I find instructions on changing lamps? I am assuming that is the problem since I have yellow or blue outlines around test and outlines of bodies.
If you have 3d looking picture and in the customer menu the convergence will not adjust---you have a convergence problem
This model (ws65809) uses two STK-392-570 convergence IC'S---both need to be replaced and the set adjusted----I can tell you what is needed if you want to know---I have repaired hundreds of these sets
Go into customer menu and select convergence--if either blue or red will not move in some direction---convergence problem---You can buy a pair of the chips on Ebay for about 14 dollars plus shipping and if you are able to do the repair yourself--you can save a lot of money.
I have instructions for this repair but I am not allowed to post MY email address here.
Let me know if I can help you--if you have questions or want options reply to this posting.
SD TECH
Oct 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Hey can any one help me with my Toshiba 46H83 rear projection hdtv? My screen is off center by about 3/4 of an inch to the right. The picture is prefect except for this. I've asked this question two times...
OK, need to go to service menu of TV and adjust HPOS data, you can move entire picture left to right or right to left to adjust it on TV screen.
Be careful NOT to initialize service data memory otherwise all convergence will be a mess.
How to go into Service Mode is written in service manual of TV.
Thanks.
Sep 05, 2009 | Toshiba 46H83 46" Rear Projection...
KP-65WV700 convergence problem
AD board is some thing else and in convergence problem only D board will be replaced.
being a TV Tech, I do repair D Board on component level.
If you need D Board part number, let me know.
Dec 08, 2008 | Televison & Video
Convergence problem
The Stk392-120 are better ICs if you would like a link to get new ics that provide free instalation instructions with pics let me know and I will post the link.
May 15, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Arcing Picture tube
get a different tech from a different store to come out, needs to replace convergence ic's good luck
please mark the post with a fixya
Feb 16, 2008 | Toshiba 65HDX82 65" Rear Projection...
My toshiba 42h81
Your convergence amplifiers have failed. There are lots of posts on this site for this problem. Take a look at this link:
http://www.fixya.com/support/t261950-43h71
There are a couple of links on this post that you will find helpful if you want to repair this yourself.
If you have more questions just ask.
Dec 28, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 57HDX82 57" Rear Projection HDTV Logo
170 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
