Question about E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop
Doesn't start When turn-on the pc, it doesn't start, only turn on the fans but there is no video and no sounds
  • Anonymous May 14, 2009
    when i turn on my computer only the fans run will not boot up and screen stays blank
  • 34 Answers
Take out all your ram and put one in the first slot turn on your system. if this does not fix it take out that ram and put another stick into the slot and power on your pc. continue this process with all your ram sticks if this does not fix your issue find a stick of ram you know works and try that
Posted on Aug 18, 2008
  • 177 Answers
Check all your connections for loose wires.Especially your power supply.
Gas package unit
the bushing or the bearing in the motor may have already worn out. or may need some lubrication. the rotor is trying to turn but it's stiff and won't continue to turn. dont continue to turn on if it wont spin otherwise you'll damage the motor further. it might also be the busted capacitor "if it has"
Jun 04, 2013 | Amana Heating & Cooling
When i start the car it makes a squeaking sound, also the fan doesn't come on it is suppose to come on when you start the car or turn on the ac the fan doesn't come on.
could be the clutch fan if your fan doesn't come on. also the belts could be to tight or the alternator belt. good luck.
Mar 23, 2013 | 2001 Hyundai Sonata
The fans getting power but not turning
Clean fans, vents of dust or any obstruction. If the fan doesn't work replace it A.S.A.P. Heat will kill a laptop.
Nov 18, 2012 | Computers & Internet
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
My fan doesn't work nor does the motor make a sound.
Need help with a fun like to bypass the which
Sep 24, 2011 | WeatherWorks CH-1640SF Fan
On line videos stop and start.
It sounds like your internet speed is not quite fast enough, or the site you are watching the videos from doesn't have the right bandwidth. If I have that problem, I tend to load the video page, then leave it on the page for a few minutes, until enough of the video has buffered.
Jul 23, 2011 | Computers & Internet
When i putu the power cable on, the led light blink once and goes off. the screen is black. no fan is moving or any sound.
You should try to start your computer without the battery installed. If that doesn't work, you should try another power supply. If that doesn't either do the trick, it could be the motherboard causing the trouble.
Jun 14, 2011 | HP 530 Notebook PC
E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop Logo
94 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
