Question about Canon imageRUNNER 400S Copier
No error code, all works but won't make a copy
No error codes have displayed, machine turns on, paper pulls through but won't copy/
  • juliesmile Aug 19, 2008
    Yes, the paper exits and yes it is blank.
  • 47 Answers
It could be a dozen different things but the most common and simple solution is the developer engage lever has been twisted too far. The lever is a smallish green or blue handle that you turn when installing new toner. It is supposed to have a stop on it to prevent you from turning it too far but if you force it the stop breaks off. The lever should be horizontal. If it is pointing up and down turn it counter clockwise until it is horizontal. The lever should be replace but as long as you are careful to turn it to the correct position it will work fine.
Posted on Aug 19, 2008
I have a couple of questions for you.
Does the paper exit your copier?
if so, is it a blank copy?
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
Ricoh ft 4022 photocopy machine displaying error code E-3.
cleaning requird clean properly with any quality cleaner then rty
May 17, 2012 | Pyle Office Equipment & Supplies
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
Error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Nov 26, 2009 | Xerox 6180MFP/N Printer
"low temp "error code : machine will not function
Hi:
The low temp error is most likely the result of a bad fuser assy that is not coming up to the proper temp. If if can't do that it will not work correctly. This would have to be serviced by a trained tech.
Andrew
Jun 26, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
Canon imageRUNNER 400S Copier Logo
old marine
old marine
