Question about Brother HL-2040 Laser Printer
50 Copies Per Toner Cartridge?
I'm running a Brother HL-2040 in a small office and we have a problem with the Toner Cartridge and the detector:
Within 50 copies of replacing the Toner Cartridge, the light invariably comes back on. We've tried several different techniques with the cartridge to get it to reset: Removing and replacing the cartridge, resettling the cartridge, and good old fashioned futzing.
We are using Brother Cartridges, not any third party brand, but if this continues we might try that.
Any solutions?
  • brightonkhk Aug 18, 2008
    Negatory, 50 copies as sure as the sun rises. We definitely have more toner, but the printer decides just to shut down (Toner light comes on, and then it won't print until we replace).
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Sounds just like the 'idiot' lights for oil changes on your car..how about this..100 copies from replacement, does the light go on?
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
SOURCE:
How do I remove the toner cartridge on HL 2040 ?
Open front cover and pull out the toner cartridge with drum unit. To release toner cartridge from drum unit just push blue lever down and lift up toner cartridge.
Feb 01, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Sep 02, 2009 | Brother HL-2040 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
New Toner Cartridge Does not Print (HL 2040)
hi!  have you check you toner, it has a white strap, you need to strip it to open the nozzle of your toner. but before you do that you need to shake it first to have a sharp print out before you would strip that white strap. have a nice day
Dec 20, 2008 | Brother HL-2040 Laser Printer
Brother HL 2040 toner light flashing
Push the start buttom and hold for 30 sec.
Nov 26, 2008 | Brother HL-2040 Laser Printer
Brother HL 2040 won't print
Sounds like the toner cartridge is faulty. I would change the cartridge.
Nov 19, 2008 | Brother HL-2040 Laser Printer
Changing the toner on a brother HL-2040 in my office
It should be one unit??? look at the toner cartridge and look for a shiny cylinder that is the drum.
you can google brother hl2040 drum and click on images on the top right of google to see what it looks like
Aug 21, 2008 | Brother HL-2040 Laser Printer
Brother HL-2070N
stars-5-0._v47081849_.gif Masking Tape Gives TN-350 Toner a Second Life, August 25, 2008 By C. MACPHAIL "cmacphail3"drop-down-icon-small-empty-arrow._v13355991_.gif
After the "Toner Life End" message appears, it refuses to printeven one more copy. Offensive...until you show it who's in charge.
Remove the cartridge and find 2 clear plastic port holes, one oneach side. The printer shines a light through these to decide when toshut you off. But it's too sudden and too early.
Cover one or both windows with a small piece of masking tape. I get about 3400 copies per cartridge instead of 2400.
(Reportthis)
Aug 17, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
97 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
