Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv tries to come on but does turns it self off
Tries to turn on over & over but does nothing
    Sergeant:
    Champion:
  • 258 Answers
Hi
It has a bad horizontal section or B+ fault. A shop can fix it but expect to pay $150 - $450 depending on the extent of the problem.
Posted on Aug 18, 2008
Hi all, when I plug my TV in all I get is the Hitachi Logo,then the set turns off, then the standby light flashes blue and red 8 times. After it flashes the process repeats it self. Nothing changes when I...
Try unplugging the tv. And holding the power button for 45 seconds or more to purge the circuits. Plug it back in cross your fingers. And turn it on.
Nov 07, 2014 | Televison & Video
Tv turning on and off by itself
Short circuited component/s at its main board. Contact any service technician to troubleshoot.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2014 | LG 39LN5300 39" LED TV 1920x1080, 60 Hz,...
TV JUST TURN IT SELF OFF
something burned means do not plug back in etc--consider getting an estimate for repair--not a do it yourself thing.
Oct 16, 2012 | Televison & Video
I turned my tv on, it then turned itself off, there is no red light, have turned off from socket but still nothing.
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Mar 06, 2012 | Televison & Video
My tv has a problem staying on and sometimes it turns it self off and turns it self back on and has become more frequent with turning it self off
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in.
Another thing to try is plug a different device into that same electrical outlet and see if it turns on/off as well. If that device also turns on/off by itself, it could be a faulty outlet.
Mar 09, 2011 | Samsung SlimFit TX-S3082WH 30" TV
Mdl # pn50a5601f when the remote button is pressed to turn on the tv it responds with no picture. The tv clicks twice and turns off. it will operate by it self trying to turn on approx. 8 times without a...
Try several inputs. See if you have the sam result. If you are watching with an antenna make sure all is connected and setup is set up.
Try set up for the TV with its' remote.If it works on the blank screen that means an input problem.
Mar 24, 2010 | Samsung PN50A650 49.96 in. Plasma HDTV
Tv wil not turn on just keeps making a clicking noise
ur relay keep try hard to turn tv on that u hear clicking noise.
+5VDC is leaking! open back cover,check power supply board.
1000uF or 2200uF capacitor is popped open or leaky.replace with known top quality capacitor.do it ur self repair will save u $200.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Tv turns its self on or off at times
I tried to unplug mine for awhile then plug it back in that worked for awhile now it won't come at all. Hope this helps abit, although i'm sure your like me and have tried it all,8)
Jan 17, 2007 | RCA 27F650T 27" TV
Proscan PS36109 36" TV
the power supply is shuting off it self becouse a short, you may have to take to a repair shop, becouse there are nothing that regular people can do, is a job for a tech..good luck
Aug 09, 2006 | Proscan PS36109 36" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
