Question about Apple Logitech Inc MM50 Portable Speakers iPod 970173-0403 Computer Speakers
Logitech mm50 speakers wont turn on
I've had my speakers for maybe a year and half and they have always worked perfectly but just recently they wont turn on at all even when plugged into an outlet. The blue light wont come on and i have no idea what do to. Please help!!
  • 5 more comments
  • karuva Aug 22, 2008
    I am having the same exact problem. My mm50 worked perfectly for the past 2 years, but just recently the power went dead. No blue or red light. I plugged into multiple outlets, but to no avail.
  • clois22 Nov 05, 2008
    The same thing happened to my mm50 today. It was playing tunes for about half an hour then suddenly crackled a bit then went completely dead. Tried different power cables but no luck. When I try and switch them on the button goes red, then flashes red, then goes off completely. Bought them on ebay about a year ago but they were brand new at the time. I am very disappointed as this seems to be a common problem with these speakers and no apparent cure.
  • Anonymous Dec 30, 2008
    I am also experiencing the same problem. For a while the speakers were running off of the reserve power (i.e. in travel mode, when the light turns purple instead of blue) but now that that ran out, the speakers will just not turn on no matter whichever outlet they are plugged into. At one point the power button did flash red for a few seconds when pressed, now nothing happens whatsoever if i press it - I think this means the spare power has completely ran out. Too bad...great speakers...this seems to be a common problem. I am going to try to contact logitech (i dunno if a spare power cord would do the trick?)
  • CB27 Apr 16, 2009
    I have exactly the same problem; makes you wonder whether this is 'built in' obsolescence.
    CB
  • Anonymous Apr 26, 2009
    i have the same problem.
    just a red flashing light now, no blue/purple light.
  • liyla2410
    liyla2410 Jul 18, 2013
    i god same here
  • liyla2410
    same here
    New Friend:
Anwser to your simple problem when your logitech mm50 when it will not power up. there are two reisistors next to the power input jack, all you need to make it work like new is re-solder both resistors and caps around the power in-put jack board and it should work like new. Anymore questions in reguards to problems with your logitech mm50 or you want it repaired contact me at, a1techman@hotmail.com and most repairs are same day with a 90 day guarantee.
Posted on Nov 27, 2012
The power plug no the circuit board has fratured. (Where you plug in the power cord) Soldier lug on back of connector has broke loose. I can't find a way to resoldier this to the board....Too bad nice tune box.
Posted on Dec 02, 2008
My mm50 speakers just stopped working
The power supply adapter is most likely the culprit. You can find a 12V Logitech mm50 replacement here: https://www.digidave.co.uk/jshop/product.php?xProd=4762
Jan 29, 2011 | Logitech Inc MM50 Portable Speakers iPod...
Logitech mm50
Hi Todd,
All instructions that comes with the mm50 can be found here: http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/3501
Thanks and have a nice day J -
Jun 15, 2009 | Apple Logitech Inc MM50 Portable Speakers...
Logitech mm50 speakers will not charge
Try either eBay, or go to Radio Shack.  You'll find them there.
Jan 15, 2009 | Apple Logitech Inc MM50 Portable Speakers...
Flashing Lights and No Sound
I am 100% sure the battery is dead.
Opening my mm50 I find that the small 2"X 1/4" battery is attached to the back, very near the charging socket. The battery is connected to the circuit board through a small plug-socket arrangement - no soldering here like iPod. So, it would not be difficult to replace it by a DIY enthusiast. But it would be difficult to find this non-standard replacement battery. Better leave the job to Logitech service, they'd would certainly replace it on charge basis.
=Subhas Chatterjee=
Feb 25, 2008 | Logitech Inc MM50 Portable Speakers iPod...
Battery down but ok with power on MM50.
The battery for the MM50 speaker is VERY hard to find. Logitech does not make a replacement battery for this unit but here is a link to a site that carries it: Replacement NTA2335 Battery for Logitech MM50 iPod Speaker
The battery has a plastic connector which connects to the board so soldering will not be necessary. You just open up the back and switch it out. Easy Peasy!
Jan 08, 2008 | Logitech Inc MM50 Portable Speakers iPod...
Logitech mm50 very little sound coming from right speaker
Check the cables and see if there is a tear, or unscrew the cover of the speaker (if possible) and see if the contact is frayed or only holding by a couple of wires. This will reduce the sound quality.
If not, the speakers are faulty, and they are not worth replacing. Just purchase a new set.
Dec 31, 2007 | Apple Logitech Inc MM50 Portable Speakers...
Logitech MM50
Yess i have both and they work fine!
haha it works with most iPods!
Nov 30, 2007 | Logitech Inc MM50 Portable Speakers iPod...
Speakers work when plugged into electrical outlet however will not work on battery power
hey u r using speakers..so i think power is not suff for them to run..so use dc flug boards..i mean direct curr...
y do u try for a batery??itz waste of money
Nov 29, 2007 | Logitech Inc MM50 Portable Speakers iPod...
Logitech mm50
I think maybe the speakers blew out because of how loud people put there IPods. It is busted so buy a new one.
Jan 19, 2007 | Logitech Inc MM50 Portable Speakers iPod...
2,162 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
