Question about Estate EED4300SQ Dryer
Changed heating element in kenmore dryer still wont heat
Changed the heating element in my kenmore dryer but still not heating. What else should I look at?
    Genius:
  • 2,920 Answers
Limit switches
Posted on Aug 20, 2008
Won't heat up
I don't know for sure but have you checked out you exhaust sometimes it can get full of lint and your lint filter take a dry dryer sheet and wipe it down you hope this helps Merry Christmas
Dec 09, 2017 | Kenmore Dryers
Changed the element,2thermostats ,thermalfuse,and a breaker30amp
bang hit that one on the nose, take the vent off and try a load probably will work then
Jul 28, 2010 | Kenmore 62992 Electric Dryer
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
Had changed heating element, dryer is working for two weeks, now the dryer is not heating again ?
Could be your high limit thermostat, your breaker box not providing a full 240 volts, or the heating element went out again, ...(this happens). Good luck...
Nov 16, 2009 | Kenmore 62602 Electric Dryer
My kenmore 70 series dryer isn't drying - changed the heating element, changed the thermal fuse, and the high limit thermostat. Lint is cleaned and the motor is running.
Are you getting any heat at all? Did you change the thermal cut-off which is mounted near the top of the heater box? This is the only other piece in the heating circuit. If you changed it already you could have problem in the timer or in motor. There is a switch in the motor that controls heat also.
May 26, 2009 | Kenmore 62602 Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Have kenmore dryer 110.86982100 does not heat changed put in new heating element and thermofuse still no heat
check and see if you have 220 volts to the dryer using a volt/ohm meter start at the dryer and work your way back following the circuit back to the fuse/breaker boxuntil you find 220 volts
Jan 06, 2009 | Kenmore 62602 Electric Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore dryer
change the thermal limiter its the tiny disc on the heater element pan and check for 220 at the outlet dont assume because its running you have full power to it
Mar 13, 2008 | Dryers
Estate EED4300SQ Dryer Logo
83 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
