Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Heater either won't light or goes out after running 5 to 10 minutes
I have a laars lite 2 model LD175N heater which has the electronic ignition rather than pilot light model. I try and start it numerous times and it won't start and you come back 20 min later and it may start right up. If you do get it running it only runs for say 5 to 15 minutes and then shuts off and then it won't restart again?
  • 6 more comments
  • space7 Aug 18, 2008
    I already unplugged it and check to see that all the wires were on the terminal correctly and tight. So this should not solve the problem.
    I looked a the parts breakdown and I'm I don't see anything listed as "ignition coil assembly". I see ignition control assemble-LD and ignition control-LD, transformer and ignition control panel
    I certainly would like to check the contacts on the device end that you mention. All I need is their location in the unit.
    What is this gaskets need replacing. I am getting confused at checking contacts and now replacing gaskets? Need more specific information regarding parts and location in the heater.
    The last response I got was regarding a BTU 250,000 unit so where did that come from. I stated in my initial correspondence that I had a 175,000 btu LD unit?
    I am going back outside and will blow out the burners, look over the ignitor section and check all the electrical connections again. One last thought I had was the problem seemed to start several weeks ago about the same time the copper tube buy the siphon loop split open letting the water out. I soldered the tubing and it doesn't leak and I disconnected the pressure switch and the water flows out the tubing in a very strong stream so I didn't think that had anything to do with it?
    I have the installation and operations manual from when I installed the heater 4 years ago. It has the exploded view of all the parts and a list of Part numbers for ordering the parts. Also inside the cabinet and on the cabinet door there are appropriate wiring diagrams for the electronics so I'm good to go that way.
  • space7 Aug 19, 2008
    I don't believe the information I received helped and at times it appeared that whoever answered me didn't even understand what product model I had. I felt like different people were just shouting out random suggestions rather then fact IE: there are three items that could cause your type of problem and it should be either 1. blah blah blah or 2. blah blah blah or no.3. blah blah blah which I didn't get and I feel this effort was a waste of $10.
  • 6,487 Answers
If you have those information already you can juist proceed with the replacement and hopefully that will fix your concern, feel free to contact us back here if you still need further help..
Good luck...........
Posted on Aug 18, 2008
    Scholar:
  • 163 Answers
i'm working on your problem,
for the while i have a link for you that should be good to check it out for any help in parts that you may want to replace in your heater so far, as you told as you have already opened the heater.
http://www.aqua-man.com/schematic.asp?heading_num=1071&s=full
i will return shortly providing further assistance
    Genius:
  • 1,689 Answers
The ignition coils should be near or within the "High Voltage Lead Assembly" it will depend on how the BTU-250,000 was assembled, but it should be in that area, please check.
    Genius:
  • 1,269 Answers
Gaskets need replacement.
Call their Support @ 1-866-927-3687 for live help
Check this link for parts assembly
http://www.epoolshop.com/index.asp?PageAction=VIEWPROD&ProdID=427
    Master:
  • 623 Answers
Make sure that the spark of the ignition is directed towards the burners...
clean burners if dirty...
goodluck
  • ritchie dempacco
    ritchie dempacco Aug 18, 2008
    try my solution or visit this site for explode view of your gas heater
    http://www.aqua-man.com/schematic.asp?he...
  • ritchie dempacco
    try this
  • 1,183 Answers
The problem you are referring to could be beacuse of the ignition coil assembly a physical look at the equipment is needed to pin point the problem. As given by the description the best guess is the ignition coil assembly.
Following is the link for the part and replacement cost involved
Thanks
Proton
  • Mandeep  Singh
    Mandeep Singh Aug 18, 2008
    Every one is just blindly copying the same link, that i have posted on the forum. As i reffered to you earlier , call the tech from Laars, in case you are not comfortable opening up the unit.
    LAARS Sales and Service
    Phone:
    800.900.9276
    Fax: 800.559.1583
  • Mandeep  Singh
    Mandeep Singh Aug 19, 2008
    In case you were not satisfied with the result or help you got , you can ask for refund for the same.
    Thanks
    proton
    Master:
  • 521 Answers
Check for any loose electrical contacts
  • 2 more comments
  • tech expert12 Aug 18, 2008
    may be some electrical wiring contacts are loose so even after trying again n again ur heater does not light up.some how if it comes in contact for some time it starts up n again it goes off.
    plse get it checked.
    hve u checked the contacts at device end also
    just check the contacts on the device end.
    the link for detailed diagram of the device is given by other expert :http://www.aqua-man.com/schematic.asp?he...
    plse do rate the solution
Convert Laars lite model lg125n to LP gas
That involves changing out the complete burner tray including the igniter/pilot assembly, burners and the gas valve. It runs deep into the cost of a new heater, (well over $1000, not installed).
Nov 27, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
My pool heater turns on, runs a few minutes, the igniter lights and the heater heats for about 3 minutes, then turns off. I see a SERVICE comment blinking and SW2 is also blinking.
im not sure what filter you have on there but do a good cleaning if its D.E acid wash it if sand clean the sand. your not keeping enuff pressure to keep it lite. take it slo
Oct 15, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
I have a Teledyne Laars Lite pool heater Model LLD 250N. When I turn the heater on it will run for 10 minutes and turn off. If I turn the power switch off and right back on it will run agin for 10 minutes...
It sounds like your pool heater might have a defective controller (the part, not you). Check the controller and replace if necessary. It could also be that you need to cycle the ignition sequence until the air is out of the gas line. It could also possibly be that your gas valve needs to be replaced.
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
The burners will not ignite
if the unit is used you might have to removed the burner and clean the pilot sometimes rust built in the hole and need to be clean out. I had the same problem.
Apr 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
181 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Michael Galve
Michael Galve
Craig Butler
Craig Butler
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
