Question about Hampton Bay 24002 Ceiling Fan
Hampton Bay "Beverly" Stopped working
Turned the fan on "high"...after a moment, the blades slowed and eventually stopped completely. Cannot get the fan (or light) to work at all now. Checked the battery in the remote; it's ok. Dip switches match. All circuit breakers are in 'ON" position. What happened? How can it be repaired??
  • Darryl Aug 18, 2008
    I just phoned TAL customer service (apparently, this company does the customer service for this model). They are sending a replacement remote control receiver which mounts in the fan. WONDERFUL SERVICE!!! This should solve the problem.
  • Anonymous Nov 22, 2008
    my hanpton bay model 344 476 just stopped working. i really like this fan. Any ideas?
Buffalo12980
  • 625 Answers
SOURCE: I need the default code for a hampton bay fan
I checked the hampton bay site and unfortunately whatever dip switch setting on the fan is, the remote needs to be matched to it. better get out the ladder!
Posted on Sep 12, 2007
SOURCE: Hampton Bay Remote
Hampton Bay Almeida 52" Ceiling Fan 52101916 ... Had fan installed remote fan would not go on ... nothing not even light ... changed batteries electrician that installed it said take it back to the store he would install another fan .. just bought fan last year HELP
Posted on Aug 04, 2008
  • 75 Answers
SOURCE: Hampton Bay Windward II dip switches
The CODE SWITCH RECEIVER should be located in the CANOPY (the bracket hanger). !!WARNING!! YOU ARE ENTERING A HIGH VOLTAGE ELECTRICAL ZONE!!
It will be tucked in among the electrical wiring and inside the hanger bracket.
Simply pull it out and you will see the CODE SWITCHES. There are 16 CODE combinations that can be used. Both the REMOTE and the RECEIVER MUST be set with the SAME CODE.
Good luck. :)
Posted on Apr 26, 2009
  • 26 Answers
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Posted on May 19, 2009
SOURCE: My Hampton Bay Windward II
I need a fan chain pull switch for my Hampton Bay 5 Blade Model 552 od--
SKU # 409-952----
MFG # 5A00007
SER # 720275940415653B
The switch controls High,Medium,Low Speed and Off.
4 Wires--Black,Brown Purple and Gray are connected to awitch, they come from a Block Capacitor (4.5mf,6mf and 5mf)
This fan was purchased around 1995 and is in good condition but needs this replacement switch---
Where can I get the replacement for this model?
Posted on Sep 22, 2009
My 32" Hampton Bay Minute
Sounds like an excellent idea. In case you don't get a certain reply, i suggest that you remove a blade from your old fan and take it with you to a store that has one on display. Check the spacing of the holes, and the number of blades. You might also find that the width of the blades and their pitch (which is determined by the bracket the blades are attached to) work out in combination to give you about the same performance. But if the bigger fan has a much flatter pitch, you might find it won't deliver as much air as your old fan did with the old blades. Good luck, Al K
Jul 26, 2011 | Hampton Bay 40106 Minute II Ceiling Fan
2 of my hampton bay ceiling fans stopped turning-one that was installed 6 years ago and one that was installed 2 months ago. I can hear the motor vibrating when it is turned on. Do I need to replace the...
mcdevito75 here, On the fan you hear, carefully turn the blades by hand just a little and see if they start up on there own. These motors are sealed units and maybe the oil is a little thick from non-use. If the baldes don:t start up, Then I would replace the fans.
Jul 26, 2010 | Hampton Bay 24002 Ceiling Fan
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
The fan blades do not turn but the fan motor can
speed switch is no good, the one attached to the pull cord. replace
Jul 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Ceiling Fan Light Switch stopped working
I was able to resolve the problem. It turned out that the light fixture part that I had received from the associate at The Home Depot was the wrong one. I needed a 3 speed not a 2 speed replacement part. However, I ended up not even needing that. Once I took the fan apart and watched it malfunction, I could see that the clear part holding the fixture rope on my older fan had another circular piece in the center that had become loose but had not fallen out. I simply used a very small piece of blue paint tape to seal back in place. Since the area doesn't get hot, I found this to be a suitable solution. Thanks for your help.
Feb 19, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton bay 54'' fan stopped working
make sure the main switch is on ,also if there is a fan switch make sure its on before using remote
Jan 04, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
My remote to turn on the light on my hampton bay fan is not workn
if you replaced the bulbs w/ higher watts it burned the circuit !!
Dec 30, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 73554 (56-ANT) from Home Depot
You need a new motor, are you still in warranty?
Oct 26, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 24002 Ceiling Fan Logo
47 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
